hey i'm looking for some pistons for my 2001 2200 all motor build up . i want ither 11:1 compression or 12:1 compression ... any places besides jbp??? thanks for any help . i justheard that jbp takes a long time to deliver.
Try
Ross Racing Pistons. I believe this is where JBP gets there's done, just cut out the middle man!
MadJack wrote:Try Ross Racing Pistons. I believe this is where JBP gets there's done, just cut out the middle man!
According to JBPs site...they use Wiseco Pistons.
3rd Gen Pistons - JBP
Might have confused JBP and someone else.
Wiseco or Ross, both are top notch!
You have to call JBP to design a piston for the LN2, but they know the motor, and you can get some awesome flat tops or dome pistons for your high compression ratio application. If you know all the specs you want, you can also try Flatlander Racing. They do a lot of custom Wiseco and JE piston jobs.
Oyyci wrote:this may be a stupid question but whates the advantage to dome pistons?
similar to the advantage of a dish piston for lower compression and boost.
12:1! Careful with compression that high! Low octane fuel = NO.
LD9 Fury! wrote:12:1! Careful with compression that high! Low octane fuel = NO.
Not only that but watch the computer. Some computrers freak out and start throwing knock codes.
