i have a  62 mm throttle body it will not fit on my car due to having a stock intake manifold. it hits the one piece of pipe .. on the manifold. and will not let me bolt it down.. is there any way to fit this on //?? or is there any way to take out the throttle wheel and replace it with a different one?? lemme know thnx..
PJ
from my understanding, you have to replace the throttle wheel with the stock one, It'll still open the butterfly just as far.
Which throttle body do you have that is 62 MM? Where did you get it from? If it was made for your application, I don't see why it wouldn't fit...
its was bought for my old beretta gtz quad 4 ho .  i figured out how to switch the wheel around now my question is how do i change the tps sensor over to work with my 97 Z also will only 2 bolts hold it tight enough to my 2.4 mani?? lemme know guyz as much info as possible
PJ
