header install - Performance Forum
header install
Friday, November 25, 2005 8:19 PM
I went to the same shop that bent my exhaust piping and he told me that he doesn't install headers because if he breaks a bolt he had no way to fix it. would I be better off trying to do the install myself or take it to a regular shop that does tune ups and etc. will I have to take my car to the exhaust place and get it welded at the B pipe? sorry for all the questions, i just want to be armed with the right information before I decide.
hugs and hand pounds, peace
Re: header install
Friday, November 25, 2005 8:21 PM
If he cant fix it, find another exhaust shop.
Re: header install
Friday, November 25, 2005 8:57 PM
but it will need to be welded? could I do the install and just have a shop do the welding?
Re: header install
Friday, November 25, 2005 11:24 PM
I dont think its called a "B pipe" but back to teh subject.
Do you have a Dremel or a hack saw at your disposal?
What kind of header do you have?I'm guessing either the pacesetter, all though these instructions will work with any of the headers out for the twin cam.
>I unscrewed all the bolts that held it to the head
> Then I unscrewed the O2 sensor in the manifold
>Next I undid the bolts that hold it on the stock downpipe
>Next I got the main part of the header bolted to the head
>Then I either connected the header downpipe to the header itself to see where to cut for the connection of the Aftermarket Downpipe to the stock one.
>Then I unscrewed the O2 sensor after the cat
>Next I undid the 3 bolts of the flange that holds the cat onto the catback piece.
> Then I cut and put it all back together, the trial and error thing will come to play in this phase. The trick is to make the cut of the stock downpipe section a little bit long so you will have enough room for the aftermarket one to slide over.
>Then I drove my g/f's car with my 2 downpipe sections to get them welded, The proper marks are crucial here.
>Brought it home, everything was right so i just bolted everything back on.
Just be really careful not to touch your O2 sensors with your skin, Take them out and be really easy with them. While you're working unplug your battery so the pcm can reset itself when you're done
Re: header install
Monday, November 28, 2005 8:05 PM
is installing this a problem if i already have my exhuast system done. I have custom pipe from the stock header back. I looked under there today and there wasn;t much room. I'm thinkin I would be better off letting someone do the install. if anyone has installed their header after they had theier custom exhaust run I would love any info that you may have.
thanks
Re: header install
Monday, November 28, 2005 8:24 PM
I installed mine myself, I got all that welded by an exhaust shop. If you prefer to have a shop installed it's your choice. But if you install it yourself you'll save some $$$ if the guy just have to weld the parts together. Do like you want, if you don't want to spend time on it, send it to a shop, it may take some time if there's rust on the bolts, but that's not a difficult job.
Re: header install
Monday, November 28, 2005 10:10 PM
L33tJbody (Brandon Gathye) wrote:I dont think its called a "B pipe" but back to teh subject.
If the car is naturally aspirated, yes it is called a B pipe. Downpipes are for turbo cars only.
Re: header install
Tuesday, November 29, 2005 6:20 AM
i just got a quote from a good muffler shop and they told me that it would cost about $105 to install my header. the shop is cowan muffler and brake in topeka. Is that a fair price?
Re: header install
Tuesday, November 29, 2005 7:08 AM
I will go to bed less ignorant this night
Re: header install
Tuesday, November 29, 2005 10:11 PM
I was put here for a reason my son lol
Re: header install
Tuesday, November 29, 2005 10:23 PM
Re: header install
Wednesday, November 30, 2005 7:15 AM
That sounds like a good price. The shops I called wanted no less then $200. So I just did it myself. Good luck with the install.
Re: header install
Wednesday, November 30, 2005 10:52 AM
I thought a "b pipe" was just a short pipe off the collectors that bypassed the cat and the rest of the exhuast?
Re: header install
Wednesday, November 30, 2005 3:52 PM
i'm getting it done on monday. $105. I'm going to put in the lower mount on saturday so I should be ready to get it dynoed in a week or so.
