injectors - Performance Forum
injectors
Friday, November 25, 2005 4:00 PM
I was wondering what size injectors i should go for...i really don't know alot about this sort of stuff...i am wanting just a little more go...nothing major...already got intake and full exhaust...so i was thinking injectors, fuel rail and would i need a better fuel pump to go with a setup like this...i dunno what size injectors my stock ones are...someone help...and also a good place to pick this stuff up...thanks
Visit me on Cardomain
Re: injectors
Friday, November 25, 2005 4:01 PM
opps almost forgot i drive a 97 2.2 manual trans thanks
Re: injectors
Friday, November 25, 2005 4:04 PM
also...while i am thinking about it ...same deal with a throttle body...what size should i upgrade to and where to get it...thanks yet again
Re: injectors
Friday, November 25, 2005 4:21 PM
nevermind the throttle body...found that info
good lord..i posted and all the replies have been by me...in like 15 minutes...hahahaha..
Re: injectors
Friday, November 25, 2005 5:48 PM
Stock injectors, fuel rail, and fuel pump are good enough for whatever hp you will be able to make with bolt ons.
Re: injectors
Friday, November 25, 2005 7:21 PM
unless you go with high boost/sprchgd
Re: injectors
Friday, November 25, 2005 8:41 PM
Shifted wrote:Stock injectors, fuel rail, and fuel pump are good enough for whatever hp you will be able to make with bolt ons.
What he said.
You might want to invest in an actual Fuel management system like a Greddy E-manage, Apexi SAFC or something of that nature for fuel tuning if you feel the need to try and fine tune how much fuel you're actually getting.
Remember, bigger injectors/fuel rail don't mean more power, you would be basically trying to supply more fuel that is not needed.
Re: injectors
Saturday, November 26, 2005 12:50 AM
Even if you have every bolt on for your motor, you are still only using about 65% efficiency of your factory injectors. I wouldn't worry about it bud. Once you have every bolt on for the 2.2 (see my registry for the list because i've got them all lol) then maybe you could dyno tune with an SAFC and gain maybe 5 hp. But... is $240 worh it to you for 5 hp?
Re: injectors
Saturday, November 26, 2005 10:46 AM
thanks guys...most helpful now another question...port and polish alone...any hp gains...
Re: injectors
Saturday, November 26, 2005 11:13 AM
Mike Smeltzer wrote:thanks guys...most helpful now another question...port and polish alone...any hp gains...
Some gains yes but it's not worth doing all that work and leaving your stock valvetrain...you should upgrade it as well while you have the head off.
Check out www.jbodyperformance.com for valvetrain parts.
Re: injectors
Saturday, November 26, 2005 11:17 AM
Re: injectors
Saturday, November 26, 2005 11:50 AM
I forgot to add, you can't swap larger injectors on to your car. Not unless you convert the fuel rail for top feed injectors or run an EIC system, which you won't need without forced induction anyways. My advice? Do a PnP, a cam from JBP if you feel like rebuilding the motor, Comp Cams 1.6 roller rockers (do a search and you'll find all the info you want on roller rockers)
Re: injectors
Saturday, November 26, 2005 11:54 AM
Spotabee Racing (The Fake Z24) wrote:I forgot to add, you can't swap larger injectors on to your car. Not unless you convert the fuel rail for top feed injectors or run an EIC system, which you won't need without forced induction anyways. My advice? Do a PnP, a cam from JBP if you feel like rebuilding the motor, Comp Cams 1.6 roller rockers (do a search and you'll find all the info you want on roller rockers)
Nice pointing that out...didn't realize he had the 2.2 OHV before.
Re: injectors
Saturday, November 26, 2005 11:56 AM
neither did i when i was giving drunken performance tech at 2:50 this morning. i suuuuuuck
Re: injectors
Saturday, November 26, 2005 11:58 AM
hahaha thanks guys
Re: injectors
Saturday, November 26, 2005 12:00 PM
no problem man. it's what we're here for.
