Is it possible to swap an 2.2 97 cavy engine with a 2.2 ecotec engine?
there is a small button on the top of the forum
IT'S CALLED SEARCH
thankyoudrivethrough
Yes it is possible.
You would need the Engine, Transmission, Upper Mount, PCM, Fuel System & Ignition System. The best thing for you to do is get yourself a donor car so you can take everything out of the engine bay.
sell it and buy an ecotec car. whew. that was simple.
Spotabee Racing (The Fake Z24) wrote:sell it and buy an ecotec car. whew. that was simple.
and a lot cheaper, if you take into account time spent, gas for running back and forth for parts, and the arm and a leg GM will charge you if you need to replace anything.
-Chris
well in that case im just going to purchase a z24 engine and replace mine. It should swap perfectly because the stickers in the car read 2.4 but the engine is a 2.2. whoever had it before swapped the engine out,.
