Getting my block bored over .040 will this mess with the head gasket because the bore is going to be bigger than the openings in the head gasket for the cylinders? Get it? Any suggestions please
http://www.cardomain.com/ride/2090440
probaly. might need a new gasket
I believe you would need an gasket to match the bore but damn... .040...you'd have to get rid of alot of material. What are you planning on re-forcing the walls with? Not even sure if it's possible on an OHV. Are you re-sleeving?
You're going to need to have the block posted.
Get the block posted? What the hell is that?
And for just .040 over? Typically .020 is done just to clean it up, .040 isn't much more.
O noes!
Smokey wrote:Get the block posted? What the hell is that?
a machine shop drills screws basically with caps into your block, 4 per cyl on each side. this is a cheap and effective method to strengthen your factory sleeves. You can get it done for about $200
You can bore .040 and run it. There's several people here running .040 over bore and 12-15psi turboed. You're only taking .020 off the walls. Take a piece of paper and fold in half then fold it in half again,that's how much is taken of the wall all the way around.
A new head gasket should be able to clear a .060 over bore without a problem.
"The FACTS are always subject to CHANGE once the TRUTH is applied"
"In the entire history of man the only stupid questions are the ones that don't get asked"
.040 over ain't much at all. Start talking .150 over and thats huge! /\ /\ /\ is right just get a head gasket for a .060 over bore and you'll be fine.
Nitrous Nate wrote:Thanks alot for the info. I was just thinkin about it and i was like $hit i might have to have a custom gasket made lol. Thanks again!
you could always call Cometic.
No but now you need oversized piston rings.
Even the OEM head gasket will accept .040 oversize.
Gilles
2.3 Ho
/\ /\ /\ See I wasn't sure if the stock one would still work but if you say so. And I would go with .040 pistons not just the rings. By boring the block and not increaseing the piston size your not really doing anything for performance.
Not only that but your motor will only last about 10 seconds. Any time you overbore you MUST use over sized pistons.
Sorry I wasn't more clear on the stock head gasket being acceptable for an overbore...
first i think any time you remove your head you should be looking at replacing the head gasket, for sure,, (fellpro or a copper) next if you are going to over bore best time to think ob the bottom end, pitons and rings will need to be changed for sure, get that bottom end ready for futuer endevors (turbo/sc) what ever
That should do the trick!! I would skip those copper head gaskets tho. I tried them on my old big block pontiac engine and they leaked coolent out the side between the block and the heads. Boy was I pissed!! Had to tear the whole damn engine back down and replace the brand new copper ones for Felpro perma torque ones and never had another problem. I know others have had good luck with them but I damn sure will never ever ever ever try to use them again.
haha yea i know... well import performance parts said that they had like 30 other cavalier owners that are also waiting for the wiesco pistons so im glad that the company is selling alot of them.
Nitrous Nate wrote:haha yea i know... well import performance parts said that they had like 30 other cavalier owners that are also waiting for the wiesco pistons so im glad that the company is selling alot of them.
@!#$ that. i'm going directly through Venoila for mine.
Nitrous Nate wrote:Just wanted to show you guys that i have plenty of room for the gasket...
Looks like carbon fiber yo
Its not thats just the coating on it. Weird texture tho... does resemble CF
