Cosmo Racing intakes - anyone know about these - Performance Forum
Monday, December 05, 2005 6:47 AM
Saw this cosmo racing intake system the other day. Anyone know about these or using one http://www.cosmoracing.com/productinfo.asp?cid=130&pid=1026
Re: Cosmo Racing intakes - anyone know about these
Monday, December 05, 2005 7:22 AM
Monday, December 05, 2005 8:41 AM
HMM, thats a great price for a eco intake. wish I saw that before I bought my K&N.
How is the fit/quality of the intake???
Monday, December 05, 2005 12:36 PM
Thanks for the search. Wouldn't mind hearing from someone that actually uses this intake, or has installed it.
Monday, December 05, 2005 12:39 PM
Monday, December 05, 2005 1:06 PM
Hope this helps! Installation wasnt bad, only thing I was missing was a piece of tubing to connect from the intake hole near the TB that goes into the crank. Was pretty simple problem to fix. Good luck, I tihnk Cosmo is one of your better choices since it's so cheap but gets the job done, and spending over 100$ on your air intake isn't really justifiable IMO.
Monday, December 05, 2005 2:32 PM
yayh i have one they are great
Monday, December 05, 2005 3:22 PM
got one on my 2.4, 68 bucks shipped, seems to work just fine
Monday, December 05, 2005 3:52 PM
I have one on my 03 sunfire the fit is pretty tight from the elbow to the hood but seems to work pretty good. The bracket that bolts the intake on can be irritating to get located though. Outside of that for the cost it is a great deal and the engine seems to like it at the higher RPMs.
Tuesday, December 06, 2005 3:50 PM
i have one on my 2.4 install was easy and works fine
Monday, January 16, 2006 6:17 PM
Just recieved mine today, looks pretty sweet. Ok I see where the temperature sensor goes, I seee where the large and small sillicone hoses hook up, but there is an L-shaped plastic tube inserted into the intake tube with a grometjust below where the rest of the items I just mentioned go. My question what goes here? I have the 04 Ecotec model.
Monday, January 16, 2006 7:35 PM
The L-shaped pipe goes to the valve cover. It should also include a cap for the other hole on the tube. I e-mailed cosmo and they said the extra hole is for the european model. Overall I am satisfied with the intake although I wouldnt buy it again. It sits too close to the battery terminal and raising it will bump the hood. It is a very tight fit.
Monday, January 16, 2006 7:57 PM
Oh ok, so the L-shaped tube goes to the valve cover, temp sensor goes in the hole with the gromet, and the smaller hose is the vent hose. And the other that has the yellow cap leave it capped.
