list of parts for a turbo setup - Performance Forum
Tuesday, December 06, 2005 10:03 AM
ok douse any one have like a list of every thing i need to put a turbo in my and i do mean every thing i need to no whart to ask for xmas and what else i need when i get my taxes back i want to be able to just sit down for a couple days and read up and put it all in myself but im not sure what all i need to replace and add for the turbo setup if any one ahs a list of what they used for there car let me no
Re: list of parts for a turbo setup
Tuesday, December 06, 2005 10:10 AM
Please mods remove the search feature since nobody use it......
it's in the ecotec build guide if I remember well, even if you don't have an eco it will be the same stuff.....
Tuesday, December 06, 2005 10:12 AM
first off i tried the search and i have a 2.4l 98
Tuesday, December 06, 2005 10:14 AM
a turbo setup isn't different from a 2.2, 2200, 2.4 or an eco, only things such as manifold and some stuff differ. Check in the eco build guide... you see what stuff you need to build your own turbo
Tuesday, December 06, 2005 10:16 AM
I'll make it easy for you :
Redd214 wrote:
The GENERAL list for a turbo'd J is this:
Turbo (generally a T3 or T3/T4 will do)
Wastegate (Internal or external)
Manifold
Turbo downpipe Flange
Bolts for turbo and downpipe flange
Downpipe
Braided oil lines with fittings
2.5" Pipe for charge pipes
Connectors and clamps for pipes
BOV and flange
FMU (I'd go cartech adjustable personally)
Bigger Injectors (if you plan to run over 6lbs of boost)
Inline/In tank pump
Boost controller (I'd go Greddy Profec)
MSD-DIS 2 (To turn back timing if you want anything over 6bs really)
TB Plenum
Lots of misc vaccum hose
Rubber Fuel lines for FPR
Oil and oil filter (for the obvious reason)
Gaskets
Gasket sealer
Air filter
Intercooler (optional, but worth it)
Some spare metal brackets for custom mounting the Intercooler
Misc bolts (self tapping), and Nut/bolt combos
Gauge pod
Boost Gauge, EGT gauge (optional but smart to have one)
(If you have a profec boost controller the boost gauge is unnecessary as its built in)
Tools:
A good toolset capable of taking the manifold off
Knife for mild cutting
Sawzall if you plan to cut your own charge pipes
File (in case you need to cut anything and don't want a sharp edge)
Dremel tool (You never know when you need to make room for things, although a good blade and a file will do the same job, but slower)
Drill (To mount your I/C and tap your firewall bolts)
Wire cutters/splicers
Oil Catch Pan
4-5 cases of beer, a weeks worth of time, and a lot of willing and capable friends.
LOTS AND LOTS of patience.
As mentioned, before you start the install, make sure you have a couple of hundred bucks and an extra car so you can run around and get all the extra crap you didn't think about the first time around. Problems arise that we don't all plan for.
Never plan that you'll "be done in time to hit the track friday night"... a turbo install is not something you rush, but something that CAN be done over a weekend by knowledgable person. I say give yourself a week because you never know what problems you'll run into.
Also, the last thing on your list to save some $$$ for and DO NOT SKIMP ON IT is a dynotune with a wideband 02 sensor hooked up.
The dynotune is of unparalleld importance when trying to get a turbo car set up right.
Tuesday, December 06, 2005 10:21 AM
i already found thanks any way sorry for the post
Tuesday, December 06, 2005 11:44 AM
I guess the boost forum is hidden to most newer users.
Tuesday, December 06, 2005 11:54 AM
hay im not that new i just wasnt thinking i kinda have a one track mind sometimes. right after i posted this i thought about that
Tuesday, December 06, 2005 11:59 AM
Yea read the boost faq's it has a lot of useful info in there
Tuesday, December 06, 2005 12:05 PM
I'm a strong believer in boost. It takes you all kinds of places but it has to be done right and done well. Always do your research and know what you are getting into.
