i have a 99 turboed z24. the car had 82 thousand miles when the motor blew. i am putting in a new motor now, but i want a slightly bigger injector. what injectors will clip in and run good for 11 lbs of boost? and what injectors do i have stock? thank you for your time
Mike
You can pick yourself up a set of HO injectors really cheap they are 32lb injectors a nice upgrade, I havent installed mine yet but I`m still N/A.
you have 24 lbs injectors stock......................
you can clip in some ford brown tops I believe are 36lbs.... they will fair very good for 11 psi .... they can handle like 14 or so ..... so your okay .......
and were you running 11 psi on those stock injectors.... if so ..... thats why ur replacing your motor....
Lee
JDM Civic Hatch
i was running stock injectors........ i @!#$ up. thank you everyone for your time it is greatly appreciated!!!
i have a 2.4 that i am turboing. I only want to run about 8-9 psi trying to get 75-80 whp, if thats possible to do with out hurting anything. What size injectors would you guys recommend for me?
Thanks Brandon
2nd Place is the first loser
i have another question, my 99 has small injectors ( the size) and my 97 has way bigger ones. is that just the way they look, or have they been replaced?
what do you mean by big and small? the 96-mid 99 2.4 had low impedence injectors that were short and about 1" 1.5" in diameter. the mid 99+ are slim and long.
Gilles
2.3 Ho
I am guessing he means size...lol
yes slim and long, lol. if i do new injectors will i need a resistor box? does anyone have injectors that will work, for sale?
