ok i installed my header and it had like a bypass tube or something comming off the flange and into the primary closest to the driver. then when i started my car there is a hole in the front of the engine by the intake manifold that is now putting out exhaust gasses to and its not good what should i do
It wouldnt be any fun if it was easy.
You didn't hook up the egr I think.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
you got a header for a egr car , and yours being a 01 doesnt have egr
what header did you get ?
if you got a pacesetter or dc sports , you can reuse your stock exhaust gakset and block the egr port on the exhaust side of the head
My friend got me one for my b-day off ebay and its called tsudo racing is there anyway to make a block for the front of the engine.
It shouldn't be coming out of the front at all if you reused your stock exhaust gasket.
I think the ones that come with those headers have a hold/provision for the egr.
Hence why you're getting the fumes.
Gotta use your factory gasket or get another from the auto shop.
-M
k im in the process of changing it
Ok i got the header on and its a beauty i also noticed some more top end and a little smoother acceleration.
so the car is running good ???
Lee
JDM Civic Hatch
or you could have just fabbed up a block off plate for the front like i did, works like a charm
2000 Camaro V6.
| SLP Loudmouth | CAI Intake | HID's |
