Pulling motor help please...again. - Performance Forum
Wednesday, March 08, 2006 7:08 PM
Hey I was just wondering if there was any way to pull the engine without disconnecting the transmission, and if anyone has any guides or sites on how to remove the driveaxles, since my manual is really vague. Thanks.
Re: Pulling motor help please...again.
Wednesday, March 08, 2006 7:22 PM
if you remove the lower subframe you can drop the engien and tranny out the bottom all together..makes it pretty easy...as far as the drive axles just pry them out,use a pry bar or big screw driver ,theyll pop out
Wednesday, March 08, 2006 7:30 PM
I pulled the motor and tranny as one out of my sunfire out of the bottom, it was a 2.4 5spd. I didn't pull the subframe, infact I had the AC unit and the belt still hooked up completely, its a tight fit but you can do it.
View my MySpace
Wednesday, March 08, 2006 9:04 PM
I pulled my 2200 out the top
disconnect all the wiring harnesses, hoses, etc
undo the driveshaft nuts, undo the steering knuckles and front suspension to get them out then pry them off of the transmission (they'll pop out)
when I lifted the OHV up I tilted the transmission down so that it would sneak out around the battery tray. I bent it up a bit, but nothing a hammer couldn't fix.
Just make sure you have some friends to help manuever the motor while someone mans the hoist.
Wednesday, March 08, 2006 9:35 PM
I just yanked a 2.4l with trans attached LAST NIGHT! Just pry out the axles, and Like PJ said, manuever it around the tray. We took out the brake master cylinder to, just for more room.
Failure is not failure if you learn from it
Thursday, March 09, 2006 10:38 AM
SpdrcrZ and i got mine out and his in with out the use of a hoist.....
Thursday, March 09, 2006 10:45 AM
TheFlyingSquirrel (PJ) wrote:I pulled my 2200 out the top
i did the same thing
