apex safc - Performance Forum
apex safc
Friday, March 10, 2006 8:49 AM
I have a 99 2.2 and i was curious if this will help abit geta lttile boost for my litle engine..i have a line on one that is decnt priced and ido plan on going booseted soon enough but im wonderign if anyone has used them on a n/a angine and if they give the gains its suposed to accordign to apex...any info is appreciated..phil
Re: apex safc
Friday, March 10, 2006 9:15 AM
Without boost? Um no, I dont think it will do you any good. This seems to be a common misconception that more fuel=more power. Adding more fuel will just richen the hell out of your car and make it run worse. You need a severe increase in air to need to change the fuel, aka boost. I may be wrong, but i wouldnt bother til your boosted.
Re: apex safc
Friday, March 10, 2006 9:50 AM
Its not even good for boosted applications since it can't adjust your fuel in boost...
Re: apex safc
Friday, March 10, 2006 10:02 AM
Shifted wrote:Its not even good for boosted applications since it can't adjust your fuel in boost...
Not good for boost, but if you were do do something like:
*ported head
*larger TB
*ported manifold
*intake
*more agressive cam/cams
(Not referring to any motor in particular)
It seems like that list of stuff would definitely increase airflow a whole lot. If someone had a setup like that, would be Apexi SAFC be sufficient for making the appropriate fuel adjustments? Or am I overthinking things again?
