a apexi safc-1 controller?????? - Performance Forum
Saturday, April 01, 2006 7:40 PM
hey everyone i just bought a sfac-1 controller and want to use it in my 95 sunfire with a 2.2 where can i get a wiring harness to plug into the controller and my car?? without splicing??
does it have to plug into the obd port? or does it got into the computer? i think 95 's were different than other years?
thanks for all the help guys
jason
norwood
gmto2nr@yahoo.com
Re: a apexi safc-1 controller??????
Saturday, April 01, 2006 8:21 PM
WITHOUT splicing? haha. good luck bud.
Saturday, April 01, 2006 9:25 PM
There is no application specific wiring harness that plugs in your computer, you have to splice the wires.
Regardless of which ODB computer you have, you have to splice the wires. You might want to solder the wires as well so they don't come loose on you from all the movement of your vehicle. It can happen (happend to me while on the highway).
Sunday, April 02, 2006 1:07 AM
ok so is there a wiring schematic one?? and i can get any wiring harness to plug into the controller? as its all the same wires just a different configuration??
thanks for the help guys!!!!!!!!!
Sunday, April 02, 2006 1:30 AM
jason norwood wrote:ok so is there a wiring schematic one?? and i can get any wiring harness to plug into the controller? as its all the same wires just a different configuration??
Here is your PCM Diagram
95-97 2.2 OHV PCM Diagram
It's a basic wiring setup that you would have to do on every PCM. Follow the instructions on this PDF:
SAFC Product Info (Installation Instructions Inside - Page 41)
Sunday, April 02, 2006 11:17 AM
heu thanks a lot for the help but my ecu doesn't look like that it has a blue plug and a clear one only, maybe you could get a schematic for that one?? thanks a lot i appreciate it
jason
gmto2nr
Sunday, April 02, 2006 11:23 AM
jason norwood wrote:heu thanks a lot for the help but my ecu doesn't look like that it has a blue plug and a clear one only, maybe you could get a schematic for that one?? thanks a lot i appreciate it
jason
gmto2nr
Did you scroll down? It has 3 connectors listed on that page...you should be one of those.
Monday, April 03, 2006 11:13 AM
so i have found every wire except for two on the schmatic, the speed signal would be the vss output right??? cant find rpm/ injector signal or throttle signal
thanks for the help as i really need it and sorry but this is the avc type -r apexi unit sorry for all the confusion!
jason
gmto2nr
