Hi guys, i am looking to make the secret cam swap but i can't find a second hand exhaust camshaft. The only exhaust cam i found have the casting number 225/455 on it. Do you think it will be ok !?
this is what a read on your site for the exhaust camshaft :
The cam casting numbers are 255/455 (which is the same number as the HO cams, but only has 0.3750" of lift, not 0.410"). The casting number on the cam housing/carrier is 22542963
you have to mesure the lift to know for sure
It's easy to do, you mesure the diameter of the round part of the lobe and you mesure the diameter of the lobe and you substract the diameter of the round part.
Gilles
2.3 Ho
