Exhaust problem. Buzzing not normal question. - Performance Forum
Wednesday, April 19, 2006 3:51 PM
Well I currently have on my car a Weapon-R header with 2.25" piping for the entire system. Also I have a 18" Magnaflow resonator and a Magnaflow Cat and exits with 2 Oval Magnaflow mufflers.
Well I just recently added the header. Before it was deep and had ZERO buzzing. Now I hear one of the mufflers, passanger side making the rice no resonator buzzing sound while the other sounds great. I'm unsure what to do? Install a resonator between the Y-pipe for the duals and the buzzing muffler? Wouldn't that just be another restriction or slow things down?
Help....
Re: Exhaust problem. Buzzing not normal question.
Wednesday, April 19, 2006 5:34 PM
It probably has something to do with the header. I've never heard of a dual exhaust doing that before. You'd think it would be the driver side muffler making the buzzing, since it sees more flow than the one on the passenger side. Maybe a small resonator would do the trick, and as long as it is a perforated-core resonator, it won't have any restriction on the exhaust.
Thursday, April 20, 2006 7:46 AM
Any more suggestions or ideas?
Thursday, April 20, 2006 8:23 AM
Sounds like the sounds waves are bouncing of each other inside the exhaust system. What angle is the y-pipe at...ei. 60-45-90? That might also be causing the problem with the added flow.
I changed my muffler after I added my header because of this same phenomina. Sounded great before, and then sounded like bee's were having fights with b.b's in a steel jar. After I changed the muffler to different design it sounded a hell of a lot better.
Thursday, April 20, 2006 8:26 AM
i have the same problem with my magnaflow duels on an ecotec. im getting diff mufflers for one. I noticed the inside of the magnaflows is very small in diamiter.
Monday, April 24, 2006 1:06 AM
are the cuts in the exhaust flush? as in no piece of metal sticking into the exhaust flow?
