can a z24 get to a 14 second 1/4 mile w/bolt-ons? - Performance Forum
Wednesday, April 19, 2006 11:51 PM
i read somewhere and was also told a z24 like mine could get into mid to high 14's with all the bolt-ons. (header, exhaust, intake & motor mounts)
i have so far motor mounts, intake/high flow muffler and stiff suspension.
im wondering if a DCsport header and a 2.5 inch catback would get me into high 14's? or do i need to also do the short shifter? im just so mad that im still running high 15's!
im not crazy about doing any pulleys, but i do want to do a clutch, a stage2 spec. how much will that really help out in the 1/4 mile?
i definately want to do header and full exhaust next, but will that shave a second off my current time? thanks for the input!
- Cameron (CaliforniaCavalier)
- www.csc-motorsports.com (my new NOR-CAL car tuning site)
Re: can a z24 get to a 14 second 1/4 mile w/bolt-o
Wednesday, April 19, 2006 11:57 PM
I'm pretty sure there's a few people on the .org that can answer this question better than me, but here's my take on it.
stick with a 2.25" exhaust, especially N/A. I think you should be good with the DCSport header, which, IIRC is a 4-2-1 header.
short shifter, tranny mounts, and the pulleys will definitely help, stage 2 clutch will too.
check the weight on those rims that you have on your car. they might be a bit heavy, and a lighter weight rim will definitely help you out.
Desert Tuners
Thursday, April 20, 2006 12:00 AM
those rims are pretty close to the stock weight of the z24 rims. i was going to go 2.5 inch exhaust because i plan on a turbo in the future, and im trying to do upgrades that are a little simpler....i know i could hit 14's with a clutch and cams, but im not crazy about having my car down for a few days while those things are done.
Thursday, April 20, 2006 12:08 AM
sorry to double post, but:
is a 4-2-1 header like the DCsport header bad for what im using it for? im intrested in that header because it replaces the cat and its a direct bolt on.
or do i want a 4-1? there cant be THAT big of a diffrence......
Thursday, April 20, 2006 1:01 AM
with a 4-2-1, you'll see a little bit of gain mid-range, where a 4-1, you'll see more top end gain.
personally, if I was POSITIVE I was going turbo in the future, I would be looking at price. you're not going to be able to use it once you go turbo. if the DC Sport is cheaper than going with the Pacesetter with a Magnaflow cat, then by all means, go that route.
the 2.5 is going to hurt you a bit, because it's just too big for an N/A 2.4. there's J's here on the .org that are running 8 psi on a 2.25 exhaust and doing just fine.
Desert Tuners
Thursday, April 20, 2006 1:05 AM
I might have given you some misinformation... here:
4-1 header gives you a high end gain.
4-2-1 is more to gain more low end tq.
In my opinion.. a 4-1 is better for the J's since the engines already produce enough low end tq.
this is from the Performance F.A.Q. up above.
Desert Tuners
Thursday, April 20, 2006 3:58 AM
i have the 4-2-1 DCSport, mainly due to the fact that the Pacesetter's quality isnt up to snuff (heard issues about the ceramic coating coming off, fit etc)
Thursday, April 20, 2006 4:56 AM
for one thing, dont get a header if you want a turbo. no sense in spending money on something you will take off your car soon anyway.
there is a guy on here that ran a 15.2 with only an intake and engine mounts on his 2.4
Thursday, April 20, 2006 5:37 AM
CaliforniaCavalier wrote:those rims are pretty close to the stock weight of the z24 rims.
More plays into it than weight.
For example...
If both of us have identical cars, run identical times stock, and you put on 18" 15lb rims and I put on 15" 15lb rims, I will run faster than I did stock, and you will run slower.
It takes a lot more torque to turn something the farther the weight is out from the center.
Thursday, April 20, 2006 5:49 AM
^^ true that...
Thursday, April 20, 2006 6:50 AM
There havent been any issues with the ceramic coating comming off of the pacesetter(its done by Jet Hot), there is however a problem with the paint comming off of the black painted headers. The paint is purely there to prevent rusting when it is on the shelf, you actually have to strip it and replace it with high temp paint. ive got the Pacesetter ceramic header and love it to death.
Ill make a sig someday
Thursday, April 20, 2006 9:22 AM
2.5 is not going to hurt him if he has other good mods. If it hurts the 2.4 so much you need to come talk with my car, because it has ran a 14.83 all motor, and on the street runs with low 14's second cars (but that is another story). Also ask a current org member who has a 13.9 GM charged car how much trouble my car gave him from a roll.
Truly pre 2000 2.4's have a hard time getting into the 14's all motor. I know someone will say something about this, but look on the org tell me how many 2.4's period are in the 14's, and how many are pre2000???? I have owned a 97 z24, I also have a 96 Z24 as well my 20001. The gearing in the getrag is better.
I would say you need a 57 mm TB, underdrive pulley, 4-1 header full exhaust. Also 14's steelies with sticky tires. Then lots of practice. Driving will be the MAIN key into getting your car in the 14's. You are not going to get in the 14's on 17's or 18's with street tires. You need to get out of the hole hard for a good 60ft, and to do that would need to launch anywhere from 3000-4000RPM's. With that said the isuzu tranny is not going to like that.
Thursday, April 20, 2006 9:23 AM
CaliforniaCavalier wrote:sorry to double post, but:
Uhmmm... Couple of things here... a 4-2-1 does not replace your catalytic converter... I'm not sure where you got that info from... and if it did (or you decided not to have one anymore) you would need an O2 simulator to prevent your car from giving an error code. Next if you, as your name implies, live in California you will still need a cat to my knowledge otherwise you will never pass emissions testing... but again Just my $0.02...
Knowledge about everything and yet an expert of nothing!!
Jack of all trades.
Thursday, April 20, 2006 11:14 AM
I have a spec list close to what you are proposing and i hope to be in the low 15's or the high 14's this year. The track just opened here but i haven't had the time to go to the track yet. My spec sheet in my profile is up to date if your interested. BTW the SPEC stage 2 clutch with the aluminum flywheel is amazing. That alone dropped a few tenths off. I can send you my numbers from my first track night, in two weeks, if you want. Also i have the Pacesetter 4-1 ceramic header and i love it. Good luck
Shawn M.
PSN ID: Phatchance249
Thursday, April 20, 2006 11:26 AM
the DC sport header does replace the cat, not all 4-2-1, just the DCsport does.. and yes i will need an O2 simulator if i get this header.
also i plan on eventually getting the magnaflow high flow cat welded in, but for now i need a header that is a direct bolt on, and the dcsport header was 1 of the only ones i could find. i want to bolt the header up, and sometime in the next year before i get it smogged ill be doing the cat with the rest of my exhaust.
i dont think the armor coated pacsetter header is a direct bolt on right? it has to be welded in? can someone verify this?
Thursday, April 20, 2006 12:00 PM
Yes you will have to cut your pipe in front of the converter and weld on the Pacesetter downpipe.
Wayne
Thursday, April 20, 2006 1:15 PM
CaliforniaCavalierthe DC sport header does replace the cat, not all 4-2-1, just the DCsport does...[/quote wrote:
Is that because it is sooo long?... I mean I knew they were long but I thought they just went to the front of the cat and then bolted up... apparently I am wrong... ah well live and learn...
Jack of all trades.
Thursday, April 20, 2006 2:40 PM
its totally possible
Friday, April 21, 2006 8:21 AM
definately possible...i was gonna try to get there before turbo but i threw a rod bearing so im starting my build. I ran a 15.3 @ 88 with a cone filter on the stock s-tube, solid mounts, magnaflow high flow cat, and removed the basic interior pieces. Never got to run with the HO mani and 59mm tb but o well. All that was in an auto.....
Good luck!
2007 GM Tuner Bash...HELL YEA
PA,MD,NJ,DE,NY and all states north caravan
Friday, April 21, 2006 8:57 AM
^^ Sweet, so there's hope for autos yet. I have just about the same setup but I am running the HO mani with 56mm tb and other mods on my auto. I haven't been to the track yet but I'm hoping to get into the low 15's/high 14's and now I know it can be done!!
"Kneel before ZOD!!!"
Friday, April 21, 2006 9:08 AM
D-LuxZ24 wrote:^^ Sweet, so there's hope for autos yet. I have just about the same setup but I am running the HO mani with 56mm tb and other mods on my auto. I haven't been to the track yet but I'm hoping to get into the low 15's/high 14's and now I know it can be done!!
Still waiting to see the first Auto in the 14's N/A.
Friday, April 21, 2006 9:37 AM
i wonder how much low compression pistons will slow me down....i could always take a stab at it
Friday, April 21, 2006 9:41 AM
an auto in high 14's would be impressive, but i doubt his will yet. i thought the same thing about my old auto lux, and i had stiff suspension, intake, exhaust and motor mounts and only ran mid 15's. also had the b&m shift kit which did help, but still no where near 14's.
but good luck!
also: does anyone know where i can get an o2 sensor and how much they run?
im probably going to get the dcsport header, bolt it right in, then use an o2 sensor for a few months while i save $$ to get the rest of the cat and exahust. then use15 inch steelies at the track and see what i run
Friday, April 21, 2006 12:52 PM
How much would a full P&P job and cams help? Because I plan on going this route next.
Friday, April 21, 2006 1:18 PM
i am hoping to have most of my n/a mods done come early summer on my auto, and i will be taking it to the track, so i'll let you guys know what the best i run. i think it is totally possible, even on an auto, so i guess we'll have to see if i'm right.
