ho or w41 cams - Performance Forum
ho or w41 cams
Thursday, April 20, 2006 5:49 PM
i have a 95 2.3LO can i put ho or w41 cams in my engine if so what would i have to do and would it be worth it
Re: ho or w41 cams
Thursday, April 20, 2006 7:06 PM
GO HERE, LOTS OF GOOD STUFF
Dark for fear of failure
An inner gloom as wide as an eye and fermenting
Roiling hate
Death gripped my veins
Unveiling rancid petals
Flowering forth foul nectar
The space between a blink and a tear
Death blooms.-mudvayne
Re: ho or w41 cams
Thursday, April 20, 2006 7:35 PM
ok thanks
Re: ho or w41 cams
Thursday, April 20, 2006 8:13 PM
Sorry for the off topic post but which cams would be better on a turbo 2.4L (LD9)? I will be running 8-10 psi until i can afford a full rebuild. Sorry if this is to vauge.
PSN ID: Phatchance249
Re: ho or w41 cams
Thursday, April 20, 2006 10:13 PM
Chris warble wrote:i have a 95 2.3LO can i put ho or w41 cams in my engine if so what would i have to do and would it be worth it.
Well you have a different steering pump setup then the older quad 4s, so you would need to change back to that, or mod the intake came to work with the newer style power steering pump. After that i dont know much, but i know someone how put the W41 cams in a 1990 LD2. Althought he seemed to slow down at the track. My guess is that the stock rev limiter doesnt allow you to use the full potential of the W41 cams.
Shawn McKenzie wrote:Sorry for the off topic post but which cams would be better on a turbo 2.4L (LD9)? I will be running 8-10 psi until i can afford a full rebuild. Sorry if this is to vauge.
Do the secret cam swap (search for the info)
Click the banner to enter the best Quad4 & Twin Cam site on the internet.
Re: ho or w41 cams
Friday, April 21, 2006 3:03 AM
If you have a manual, it's possible to use the Ho cams and W41 cams without changing the chip. You don't get the full power tough.
If you have an automatic, you'll have to bring the intake cam to a machine shop to get a lobe done for the cam position sensor.
Gilles
2.3 Ho
Re: ho or w41 cams
Friday, April 21, 2006 5:19 AM
i have a manual ok so i need to mod for power steering pump and put a ho chip in is that all.can i take the govern/rev limiter out?
Re: ho or w41 cams
Saturday, April 22, 2006 12:04 AM
that answer comes at the other forum...but in a word it will increase your rev limiter to 7400 with the W41 setup and 7200 with the HO setup. The Mantapart chip also allows you to use the added RPM limits in all gears
Also, mantapart sells a modded cam for use in the 95 cam tower and for the 95+ P/S unit.
Problem is, actually getting the parts in a timely fashion, or talking to them. I lucked out, I went to meet them in person, so they couldn't avoid me.
Re: ho or w41 cams
Saturday, April 22, 2006 12:01 PM
iam going to go with the 95+ ho cams from mantapart thanks hotbug
