We switch engines from a 92 cavy stardard to a 94 cavy auto and we can only get it to turn over. what are all the reasons why we cant get spark???
wrong firing order
bad plugs or wires
coil packs bad
starter motor
you scratch my ride IMA EAT YO CHILDREN
Plugs, Wires, Ignition Coils, Ignition Control Module, Cam sensor, Crank Sensor , or PCM. Check all the connections and wiring to the sensors. It's possible you may have a loose or unplugged connector, or maybe worse, mixed some up. Good Luck.
