Does anyone know if there is any other threads about swapping the Cobalt 2.0L into a Cavalier? or where I can look to compare the J-Body platform to Delta platform?
Nope sorry... it apprently hasn't been done... yet...  There are a bunch of guys who can tell you the differences and I'm sure they will weigh in soon enough....  BTW you will lose some functionality from my understanding if you were to do this swap do to things like the drive-by-wire in the cobalts and such...
Knowledge about everything and yet an expert of nothing!!
Jack of all trades.
did you by any chance try,.... oh, i dunno......     the SEARCH BUTTON?!?!?!?!?!
This is i think the 6th, myabe 7th thread in the last month on this topic.
In short, the transmission from the SS doesn't fit directly (MAYBE something could be done with custom mounts... MAYBE), and since the LSJ's crank has a different flywheel bolt setup (i think 8 bolt instead of 6), then you can't use the LSJ with the J-body F23 trans.  Just put the LSJ supercharger setup on the L61.
Arrival Blue 04 LS Sport
Eco
Turbo
Megasquirt
'Nuff said
i said it before and ill say it again....cobalt engine swap = someone with more money than brain cells
 you have too many other options for alot less money that come out to More power.....yes,try the seach button
you cna swap in a 2.2 ecotec  and turbo that for far less money and get more power out if it  then you would the 2.0 eco
search button is your friend
to find the infamous search button you must go through the newbie forum , first in order to start your quest for knowledge, young glasshoppa
