I did searching on the forum, but couldn't find any results. Does the ecotec come stock with low or high impedence fuel injectors? And low impedence is the same as saturated, correct? And how much cc or lbs./hr do the stock ecotec fuel injectors have? Thanks in advance.
http://www.cardomain.com/ride/2208703
i think the 2003 AND 2002 ecotecs are high impedance while 2004-2005 are low impedance...i think..i am probably wrong
Yes stick with high imedence!
(website under construction)
Yeah just found out high impedence is for our Eco's. Stock cc is 242cc, right? I might bump it up to around 300cc. All I need to find now is a fuel pump and adjustor.
12.0ohm, stock is 24lb, 252cc
you need resistors to bring it down to the right ohm
