swap 2.4 twincam for 2.4 dohc - Performance Forum
Tuesday, July 11, 2006 1:37 PM
I sat here and thought a while about it and tried to do a search. But in the end I really did not know what to put down for a search, or even what was the right place to put this post. So I'll put it here and if it gets moved I'll know later where to put something like this. I was wondering is it possible to swap the 2.4 twin cam cover for the 12v quad 4 dohc cover on the 2.4's? I like how the Quad 4 cover looks over the 2.4 twin cam look. I was thinking the only thing I might have to change is the white plastic peice that the spark plug boots fit into. Or would I not have to do that? I have a 97 Z24. Thanks for the answers!
My car has two speeds, fast and faster.
Re: swap 2.4 twincam for 2.4 dohc
Tuesday, July 11, 2006 1:50 PM
OOPS! Sorry my bad not the 12v QUAD 4 DOHC but the 16v QUAD 4 DOHC. Thought I better change that before I was beatten with a flip flop for getting that wrong.
Tuesday, July 11, 2006 2:27 PM
Yes you can, just swap over the coil houseing the the ignition module. Use your parts, just the Quad IDI cover.
Tuesday, July 11, 2006 8:51 PM
Ok cool thanks!
Wednesday, July 12, 2006 6:07 PM
if its a 95 quad you wont need to change the housing or electronics...but odds are your not gonna get a 95
Thursday, July 13, 2006 1:28 AM
Well, no matter what just to be on the safe side I'm going to swap everything from my current cover over to the quad cover.
Thursday, July 13, 2006 7:04 AM
Shouldn't be a problem. Just use your stock bolts. Your washers won't fit, but you don't need them anyways. You might get a grounding issue like I did... So if you have problems after you swap make sure that's the first thing you check.
<img src="http://www.saskgmperformance.org/Matt/sig2.jpg"/>
Sask GM Performance (formerly SaskJbody) president
