So Kyle's 2.4L auto took a dump a few months back. Here is what his car looked like last year:
We decided to do an ecotec 5spd swap instead of just going back to the 2.4L. He picked up a cut-car. Its an 04 sunfire with 50.000km (30,000 miles).
Well last night we finally got busy with the sawzall and started tearing the donor apart:
http://home.cogeco.ca/~pteahan2/Kyle/eco005.jpg
http://home.cogeco.ca/~pteahan2/Kyle/eco006.jpg
http://home.cogeco.ca/~pteahan2/Kyle/eco009.jpg
http://home.cogeco.ca/~pteahan2/Kyle/eco010.jpg
For anyone one curious, there is actually TWO mounts have have to be welded into a 95-99 in order to do the ecotec/5spd swap, not just 1. There is a mount below the battery tray, and a second mount below the master cylinder. Rumour has it that you can buy these mounts from GM (instead of having to try to cut them out) Does anyone know a part number?
Thanks!
That trans and motor doesnt look too healthy... I suggets cleaning it up and tearing off the valve cover to see a little inside or something... thats a lot of fluid there.. unless the car was upside down at some point... but damn...
on the other hand good luck and if you need any help shoot me a message
LE61T PTE6262 Powered
QBE (The Boosted One) wrote:That trans and motor doesnt look too healthy... I suggets cleaning it up and tearing off the valve cover to see a little inside or something... thats a lot of fluid there.. unless the car was upside down at some point... but damn...
Ya, itis a bit of a mess, but nothing is leaking... when he bought the car it sat outdoors with no hook on it for about a week. it did have the intake plumbing still on it so it should be fine. Either way the engine is getting torn-down & rebuilt with wiseco pistons & eagle rods to handle the turbo that is going onto it
You had no problem pulling it out without removing the axles?
we just in-did the bands and seperated the shafts. he is getting bullet-proof drive shafts so we didnt really care too much about these ones. Also, with not being able to step on the brakes to stop them from spinning while turning the axle nut, and having sat with no wheels on it for a week, the nuts were rusted right on.
i want the dash , and dash pad and a/c ducts
now thats what i call a compact car
can I have the gauge cluster for free?????????????????????????????? Pwease?????
nice man! grats! sweet cav btw
[quote=97cavie24ls(JDM&00s/c sedans™)]i want the dash , and dash pad and a/c ducts damn beat me to it...
already gone. LOL
The01Cav wrote:can I have the gauge cluster for free?????????????????????????????? Pwease?????
no dice, needs it for the car to run.
Pat wrote:[quote=97cavie24ls(JDM&00s/c sedans™)]i want the dash , and dash pad and a/c ducts
already gone. LOL
Actually you do not. The 2000+ set-ups wil rum without a gauge cluster, of course you would not have gauges.
I'm just messin. I'm lookin for a fire cluster but I need a standard one not a metric and that one looked metric. None the less looks like alot of fun someday I'll do that to mine. Later man.
Make sure you post pics and instructions when you actually install it, so other 2.4 twincams can follow suite! Please
Lance Sharpe wrote:Make sure you post pics and instructions when you actually install it, so other 2.4 twincams can follow suite! Please
This information already exists. It does not matter what motor (2200, or 2.4) your are going from it si still the same work. What matters is if it is or was a manual (5 speed), or Auto, and if the car is 95-99, or 2000+. That information matters for the same reason regardless of motor type.
So we got the cabin completely stripped last night. Got the dash & all the cabin wiring out. Pulled out all the pedals, as well as the suspension:
And here is the remains of the chassis ready to go to the metal recyclers:
All thats left on it is the rear trans mount before it leaves... were gonna try to cut it out and see if we have any luck. Otherwise GM wants $55cdn for a replacement mount.
John Higgins wrote:Pat wrote:[quote=97cavie24ls(JDM&00s/c sedans™)]i want the dash , and dash pad and a/c ducts
already gone. LOL
no gauge cluster is actually a good thing, because this is going into it:
it just needs to be painted and align / bolt down the gauges.
Pat wrote:John Higgins wrote:Pat wrote:[quote=97cavie24ls(JDM&00s/c sedans™)]i want the dash , and dash pad and a/c ducts
already gone. LOL
make sure you take pics on how you install them guages!!
Kardain wrote:Tonite on Fox:
When X's attack
