Building 2.4 N/A for everyday - Performance Forum
Tuesday, July 25, 2006 11:44 PM
I am looking for options to building up my LD9.
The basics:
250 whp on a daily driven car.
Pump gass, willing to tune it on premium
Current Mods:
Engine:
* Vibrant Intake
* Custom 2.25" cat-back
* Tenzo R muffler with 4" burnt titanium tip
* fidenza short throw
* Pacesetter ceramic coated 4-1 headers
* Magnaflow high flow cat
* 2.3 HO mani swap
Getting/doing:
Secret cam swap
P&P head
Full valve train build, springs, valves, retainers, guides, locks
Rods
JBP neutralizing balancing shafts
Lighter pullies, should be here tomorrow!
The part i need help on is the compression i can run.
Can i run 11:1 pistons on these cams with pump gas?
I really dont want to go to big on the cams cause i want to drive it daily, or are there cams out there that aren't really lopy and retain some low end?
Thanks for the help, anything else you sugest?
*yes i did a search
PSN ID: Phatchance249
Re: Building 2.4 N/A for everyday
Wednesday, July 26, 2006 3:07 PM
JBP stage 2 cams...nice top end still maintained decent low end.
Wednesday, July 26, 2006 7:01 PM
How much more agressive are thoese then the secret cams?
Anyone else?
Can i really get that much power off a daily driver N/A?
Wednesday, July 26, 2006 8:14 PM
you canget that much power..karo did it...but he did alootttt more than that if i remember right
Wednesday, July 26, 2006 11:05 PM
Well hopefully he will jump in here and respond.
How hard would this to be to tune? I am hopeing the HPtuners softwear with a wideband O2 will be enough. Or will i have to go standalone with something like AEM EMS?
Thanks.
Shawn M.
P.S. I am not talking just BS, i am trying to get an idea of what this will take in order to decide between this and a turbo so i can start building the engine up.
Wednesday, July 26, 2006 11:16 PM
sounds like your doing the same thing im doing. although im not going for hp, im going for low 14's all-motor. ive done a lot of research, and accordding to what i know hp tuners should be perfect for you...and if you ever go turbo instead of all motor you can use hptuners for that as well!
- Cameron (CaliforniaCavalier)
- www.csc-motorsports.com (my new NOR-CAL car club site!)
Thursday, July 27, 2006 2:01 AM
Engine Modifications:
• 2.3 HO Ported Intake Manifold
• Accell 92-96 Corvette LT1 Adjustable Fuel Pressure Regulator
• Apexi Super AFC
• ARP Head Studs
• ARP Main Studs
• Blueprinted Engine
• Balanced Engine
• Car Customs Upper Engine Mount Insert
• Car Customs Lower Engine Mount
• Car Customs Stainless Steel Competition Intake Valves
• Car Customs Stainless Steel Competition Exhaust Valves
• Car Customs Competition Valve Springs
• Car Customs 75mm Throttle Body
• Car Customs 4 Inch Race Intake System
• Car Customs 4-1 Header 1 Ύ Inch Primaries 3 Inch Down Pipe
• Clevite 77 Rod Bearings
• Clevite 77 Main Bearings
• Eagle Forged Connecting Rods
• Holley 255 LHP High Output Fuel Pump
• Miller Performance Port & Polish Head
• Miller Performance Gear Driven Oil Pump
• Miller Performance 2.4L LD9 Competition Crank
• Miller Performance 75mm Throttle Body Flange
• Miller Performance Competition Oil Pan
• Miller Performance Crank Gear
• Miller Performance Competition Prep Block
• Miller Performance Competition Intake Cam
• Miller Performance Competition Exhaust Cam
• Miller Performance Exhaust Lifters
• Miller Performance Intake Lifters
• Miller Performance Exhaust Cam Tower
• Miller Performance Intake Cam Tower
• MSD DIS II Programmable
• NGK TR6 Spark Plugs
• O’Ringed Block
• OBD-1 Computer Conversion
• W41 Racing Chip
• RC Engineering 320cc Injectors
• SCE Gaskets Copper Head Gasket .060 Thick
• SPEC Custom Competition Clutch Kit
• SPEC 8.8 LBS Billet Aluminum Flywheel
• Unorthodox Crank Pulley
• Venom Fuel Rail
• Wiseco 10.5:1 Compression Forged Pistons
• Wiseco 91mm Piston Rings
• Wiseco Chrome-Moly Wrist Pins
That and alot of knowledge gave him the power you're looking for. So unless you go turbo, you won't achieve your goal.
Gilles
2.3 Ho
Thursday, July 27, 2006 6:49 AM
Mfk-223 wrote:Engine Modifications:
• Apexi Super AFC
• ARP Head Studs
• ARP Main Studs
• Balanced Engine
• O’Ringed Block
• W41 Racing Chip
• Venom Fuel Rail
what did that run all motor 1./4mile?
Thursday, July 27, 2006 7:05 AM
choko wrote:what did that run all motor 1./4mile?
13.125 @ 101.01mph (from the Top Ten Honor Roll in the Racing Forum)
That was on a gutted chasis. I'm not so sure that would be an everyday car.
Thursday, July 27, 2006 7:43 AM
Thanks guys.
I would be happy with Cali Cavy's goal. Anyone know how much Karo's car makes?
Last question. Will a car with what i want done be drivable everyday? Objiously its not going to run like stock, but will it be a nightmare? I know there are more peps on the site that have/are building a NA 2.4.
Shawn M.
