Sounds Like Its Going To Blow Up Past 4K,Timing?? - Performance Forum
Friday, July 28, 2006 12:47 PM
Okay my GF has a 1996 Cavalier 2.4 Vert 5 speed. I did the engine swap and did the timing chain and guides and tensioner. The car has no power and sounds like it is going to blow up (Literally) past 3500 RPMS. The motor has 80K on it, the car has a cone filter and a pace setter header into stock exhaust system. I replaced the fuel filter and plugs like others had said but its still slow, could the timing be off a tooth?
Let me know
Chris
Re: Sounds Like Its Going To Blow Up Past 4K,Timin
Sunday, July 30, 2006 8:45 PM
Bump, anyone know anything on this site?, lol.
Sunday, July 30, 2006 10:02 PM
well this is more of a maintenence issue not , performance
but my guess is you got the timing off
Monday, July 31, 2006 7:08 AM
Does it idle normally?
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Monday, July 31, 2006 9:33 AM
Yea it idles perfectly, I just dont know whats going on, the HG is fine, why no power?
Monday, July 31, 2006 9:45 AM
sounds like the timming is off
Monday, July 31, 2006 1:40 PM
either the timing is off, or when you replaced the tensioner it didn't set right (oil raised)
Monday, July 31, 2006 7:28 PM
I think that is it, I am doing a tranny on it in the next few weeks, I will pull the engine and tranny and rebuild the motor. I will have the head cleaned and milled to raise the compression a bit, cant be good driving it with timing off like that.
Monday, July 31, 2006 8:40 PM
could be the tensioner on the chain had the problem when we changed my cams. Had to replace it after a test run.
all the time
Tuesday, August 01, 2006 9:42 AM
I replaced the tensioner when I did the motor swap the first time along with the guides and the chain, maybe it was defective?
If anyone knows of a 5 speed tranny anywhere let me know, I need one!
Saturday, August 05, 2006 7:58 PM
Well I fond out what it most likely was, the fuel pump just quit on it yesterday. So most likely the pump was starving the engine of fuel and bogging it down.
Oh well how much is a new pump, anyone know off hand?
STILL LOOKING FOR A TRANN! Anyone in NY?
Sunday, August 06, 2006 7:37 AM
did you reset the tensioner? you have to push it all the way in and it will tighten up instantly... (it says, " see manual to reset") unlikely it would wreck, but always needs to be reset, by pushing it all the way in and it pops out.
Tuesday, August 08, 2006 10:43 AM
Well I dropped the tank today and am replacing the FP, it was dead. Hopefully have it back together tonight and take it for a drive!
Wednesday, August 09, 2006 11:00 AM
you should double check and make sure the timing isnt off rather than sit here and guess. ? id double check it anyway a @!#$ted out fuel pump will def cause the car to run liek ass, i was subject to that myself earlier in the year.
compared to your s/ced car its gonna feel slow.
Wednesday, August 09, 2006 12:32 PM
roughtly about 300 something for the fuel pump , it comes as a module , meaning everything around it
Wednesday, August 09, 2006 2:20 PM
I have a stocker outta a 2000, I paid 135ish USD for my walboro, if you are interested in my stocker PM me
