SpdRcrZ and Lenko, If I remember right you guys have the MSD setup, but anways, to make a long story short, I am nearing the re-installation of my built motor, and will be installing my Dis 2 box/coils/adaptor blocks/3bar map, and I had a simple diagram that showed exactly how it got hooked up on a 2.4 with the adaptor blocks, and I CAN NOT find that digram, it was like drawn in Windows Paint or smoething like that, simple but very effective, and I cant find it. I was wondering if any1 has this diagram saved by any chance??? Been searching the archives, but all of the links dont work so...cant pull it out of there.
I don't have the diagram... but my original install instructions are on NY J-bodies library:
http://www.ny-jbodies.org/library/engine/2.4/msd2/msd_dis.asp
You'd have to take the three wires off the ignition module.... two white wires and one brown... connect those to the inputs on the MSD DIS-2... then take the outputs and connect them to the MSD coils.
Not terribly difficult.
Those directions were only for the Dis-2 with stock coils correct?
Yup. But you still take the three wires from the ignition module, as the input to the MSD. The part where I solder the output from the MSD to the stock coils, just wire that to the MSD coils instead. Pretty simple.
I did the 2.2 coil conversion, then added the DIS II....... but its pretty much the same way as how Lenko described.
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
Will this diagram work??
Jason
99 Z24
Racers Edge
Johnny Mack Turbo Systems
Engineered Performance
ahhh Jason, I love you, that is the one, I had it, but I lost it somewhere or some1 threw it away on me!!! Where did you find it?
Does anybody have a list of the all of the part numbers needed to do this to a 97', and any sugestions on where to buy everything?
I had it on my computer at work. I saved it a long time ago for a rainy day
Jason
99 Z24
Racers Edge
I saved it on my computer and printed it out and put it in the box with my MSD 3bar map sensor...hopefully wont lose it now.
