removing intake box - Performance Forum
removing intake box
Friday, July 28, 2006 1:33 PM
Ok so ive searched and found a couple helpful searchs but i was hoping someone could do a small write-up or explain how to get out that annoying - air restricing black box by the wheel.....So basiclly can you just help tell me how to get the dang thing off? (I got a 2002 sunfire ln2 (2200) Thnx
Re: removing intake box
Friday, July 28, 2006 1:59 PM
what one are you talking about. the actual air box or the godforsaken hunk of plastic in the wheel well?
Friday, July 28, 2006 2:13 PM
the godforsaken hunk of plastic in the wheel well lol thats what im talking about
G Russ wrote:Ok so ive searched and found a couple helpful searchs but i was hoping someone could do a small write-up or explain how to get out that annoying - air restricing black box by the wheel.....So basiclly can you just help tell me how to get the dang thing off? (I got a 2002 sunfire ln2 (2200) Thnx
It just unbolts. I belive I had to take my fuse box off to remove it.
Friday, July 28, 2006 2:17 PM
take the nose off, its easier.
Friday, July 28, 2006 2:36 PM
im going off the top of my head from installing my cai for my cavi, so dont quote me 110%. i had to take off my fuse box, inner fender, and the wiper fluid resovoir for xtra room. it was held in by a plastic fastener that you can see for the engine bay. u can just the tip of it poking through. once you get that look for nething else cause i dont remeber EVERYTHING that needed to be taken off. but once you do just give it a tug and it should come right out. good luck
Friday, July 28, 2006 2:55 PM
its not difficult...i spent about 45 minutes fiddling with tools under the hood and got it popped out...mind u i have a 97 2.2 cav...not sure how diff it is on the fire...but it came out really easy for me...i didnt do everything that justin ^ said in fact i just took out a couple bolts or snap locks on the box i think it was and that was it...yea remember to tug tho
the cardomain
Friday, July 28, 2006 2:58 PM
95-99 is slightly different than the 00-05 ones.
Take out three 10mm bolts that attach the whole bong/washer fluid reservoir to the car. Cap off the washer fluid line, or you'll lose it all on the ground.
Once it's out of the car, put a pry bar or whatever between the tank and the bong to separate them.
I've been able to do 95-99 ones in the car... but 00+ I have to take them out, or I break the washer tank.
Wednesday, August 02, 2006 11:59 AM
Is the washer tank connected?
Wednesday, August 02, 2006 3:30 PM
my godforsaken hunk of plastic in the wheel well was held in by some plastic clips and a some screws. couldn't get mine out out right away. there was a plastic clip all the way in the back that i could not see. but it came out soon enough.
then again, its been almost 3 years since i removed mine. so i sort of forget. LOL
Thursday, August 03, 2006 4:30 AM
When i took mine off I removed the headlight from that side. You can look straight down on the "hidden" bolt that way. You have to take the front inner fenderwell out, pop the little plastic attachers out (move the inner plug with a screwdriver & pull the center out). There's a bolt that attaches the wiper fluid jug to the wierd intake silencer so don't forget that or you'll break the wiper jug.
Don
Thursday, August 03, 2006 5:51 AM
seriously....just rip the thing out. ... take off your wheel and unbolt your wheel well covers, then pull that @!#$ as hard as you can. haha I'm sure theres an easier way, but my way works too.
deleted
Thursday, August 03, 2006 5:53 AM
dont worry about the windshield wiper fluid. Its not attached to the air box, it is just sitting next to it...the crowbar idea is a really good one.
deleted
Sunday, August 06, 2006 2:35 PM
I just bought a used Cavalier, haven't picked it up yet... is this a water separator/silencer that you're talking about? If so, I think I'll be ditching it
