Need help with hoses of of TB - Performance Forum
Thursday, August 17, 2006 1:05 PM
I need help finding where the hoses for from the TB go, I thought I had them right but not sure now. If anyone could tell me or better yet take a pic I would appriciate it.
Thanks
JHound
I took a Grey Hound bus to the 2005 GMSC Bash
http://memimage.cardomain.com/member_images/9/web/501000-501999/501209_5.jpg
Re: Need help with hoses of of TB
Thursday, August 17, 2006 1:17 PM
I'll assume this is for a 2.4L?
There's four hoses... one big one goes to the metal crossover pipe which connects to the brake booster.
There's a not-quite-so-large one which is the EVAP solenoid (mounted by your a/c compressor)
The two small ones are for the FPR on the end of the fuel rail, and the other goes thru the harness to the passenger compartment, ultimately going to the heater controls to provide vacuum to change the heat/cooling vents. This isn't present on the 03-05 Ecotec as they're cable controlled.
Thursday, August 17, 2006 5:39 PM
If the evap hose was gone would that cause a bad vacuum leak?
JHound
Thursday, August 17, 2006 10:28 PM
if the spot on the t/b where it is supposed to plug into was open and not capped off yes.
