could anyone post pics of both sides of the 2.4L throttle bodies for the 3rd gen j-bodies please? im looking for the 96 or 97 to the 99 model years. i experimented with porting both sides but left the stock TB blade. also what is the mm of the blade as well as both the outter rims of the TB? if the side where the air is going into the intake manifold is slightly increased due to the porting is it worth porting it or not? please let me know and thanks for your help.
fst100
Here's a link to my server, with all sorts of TB pics... stock 99-02 (I don't know if there's a difference between the 96-98.. I thought they were all the same, just the intake manifold changed?)
http://24.81.69.1/Cars/My%20Cavaliers/BFZ/tb/
Have a look around...
I think the diameter of the TB plate is 52mm stock... or 56mm... can't recall for sure. Mine's 62mm
well... 60.83...
will i'll have to take some pics. i think the tb blade is about 55/56 when i measured mine. i didnt get the chance to measure the side of the tb where it enters the manifold, but i did measure the rim of the section where it connects to the intake piping. i measured about 69mm. what is the measurement on a stock 2.4 tb?
Well since the 2.4 and the 2.2 2200 uses the same throttle body, do a search, i know i posted a few dozen pics in the past.
will i already got pictures courtesy of john lenko, thanks lenko btw. so it is ~52mm at and around the tb blade. so whats the outer diameter where the intake plugs into as well as the outer diameter where it goes into the intake manifold? i also saw mastin's post on the venom manifold, 59mm inlet IIRC. TIA
i'll try to post some pics of my port job, not the best, but you be the judge. the blade is still stock but i smoothed out the outlet going into the manifold. hopefully the pics are clear since i will be using my crappy cell phone to take pix
