fuel pump? - Performance Forum
fuel pump?
Wednesday, August 23, 2006 8:18 PM
well iam doing a complete engine rebuild these are the mods i will have done
ported head, every bolt on header, ho manifold, pulleys, intake, 56mm t/b, lightened flywheel stage 2 clutch
jbp stage 2 cams, forged 11.1: comp pistons, forged rods, 2.3l oil pump conversion, 2 1/2 '' exhaust
will the ford brown top injectors work i mean am i going to get all the fuel i need for my mods?
so will ford brown top injectors be enough ????
and will i need a higher flowing fuel pump????
Thanks,
Paul
Re: fuel pump?
Thursday, August 24, 2006 2:18 AM
32lbs/hr would be enough.
The only realy modification to the engine is Ho manifold, TB and cams.
Not enough to need 36lbs injectors.
I have 12:1 compression on my 2.3 with W41 hot grind 2 cams and I'm still on stock injectors. Kind of risky but everything is fine. I'll be changing them this winter.
Gilles
2.3 Ho
