does anybody knows if the cobalt ss stage 1 injectors will fit 2.2 eco
i got2.2 ecotec and i got supercharger from acobalt ss and am getting a good deal in this kind of injectors so you are telling me that they do fit.
Thanx for feedback
the stage 1/2 injectors are 42lb , way to big for use on ours
you want the standard 2.0 lsj injectors they are 36lb
[quote=97cavie24ls(JDM&00s/c sedans™)]the stage 1/2 injectors are 42lb , way to big for use on ours
he said it
you want the standard 2.0 lsj injectors they are 36lb Now the 2.0 injectors will fit in my 03 2.2 eco?
Sort of. You will need to come up with a way to raise the injector cups(LSJ injectors are shorter). This is my solution:
I took an injector cup with me to a local hardware store and started matching up washers and found these:
I justed 2 washers under each cup.
Tinkles
2003 Cavalier 1SV
Bagged and Blown
I will runing 8-10 psi. Will the 36lb injectors be ok or should i get 42lb injectors
Stock pulley is ok with the 36lb injectors, once you drop down in pulley size you might want to get the 42's (under 3.1 pulley)
if you have a tuning solution (HPT), and you are even thinking of upgrading in the future, just save yourself the hassle and get the larger injectors and tune it once...
how are all you having problem with these injectors?
i have an 2004 and the injectors fit fine
Built&Boosted moar
i'm going with the 42lb injectors. Anyone know where i could find them??. tune is in july and need to find them quick. thanks
zzperformance.com same ones for the cobalt ss. Get the harness too.
Check out the Cobalt SS Board..People are selling them cheap used..I am running them in in my N/A Set up...They work well.
May sound good..But I paid $50 Canadian for my injectors with 30 thousand KM on them...Works for me..
It doesn't plug in. BUT, you can repin your stock connector with the new harness. Eliminates all the need for soldering and splicing. And if you ever want to go back to stock you can just put the original terminals back in the connector.
Can never be too big, you have to tune them anyhow might as well go with larger ones then in the future when you upgrade you won't have to swap out the injectors too.
Don't buy from MANTAPART!!
There is no easy ways to get HP, no magic box or gizmo... And if you get more hp, there's no way to make your car still behave and sound like a stock one. More hp usually makes your car louder, more vibrations and harder to drive...but still people hope or think maby there's some magic way to have it all, comfort, stock sound and drive.
I have an 02 ECOTEC. Will the LSJ Injectors bolt right in and can I use my stock injector clips? I have no harness or anything BUTonly the LSJ injectors waiting to be put in. What would I need to complete the swap? Nothing right, or so I think. Anyone tell me?
"FRIENDS DON'T LET FRIENDS DRIVE STOCK"
I think the 02 is different fuel rail...are they delphi injectors??
Siemens! I think the 03 is different?? I hope, crap! These LSJ injectors are supposed to fit an 02 eco. Anyone know? And can I use stock clips on these injectors?
Squirl.. I know you know the answer!
The answer is right here on JBO...
...pssssssssssst... the SEARCH button,
Search huh? Okay I'll try it. But hey, if you know, just tell
Quick question. I just got some 42lb injectors with a used supercharger. I still need $600 worth of parts to put the supercharger on. Will it help or hurt me to go ahead and install and tune for the 42lbs before I use the supercharger? All I have now is CAI and exhaust.
