i wasn't sure where to put this but what all do i need to remove? and cap off?
compressor, condensor, all the lines, the tank, and two lines that come off the firewall
DaFlyinSkwirl (PJ) wrote:compressor, condensor, all the lines, the tank, and two lines that come off the firewall
do i have to plug any thing?
Umm...common sense tells me that all the open lines, you will have 2 coming out of the firewall, you can cap. Probably some shorter bolts to go in the holes that held on the a/c compressor, I am not sure if on a 2.2 those bolts hold anythign else other than the a/c compressor or not, if they do, you will need some shorter bolts.
Be careful when opening up the lines. Just because the ac doesn't work doesn't mean there isn't still refridgerant in there, and it's not something you want sprayed in your face or on your hands.
John Wilken
2002 Cavalier
2.2 Vin code 4
Auto
Fst Cavy wrote:Umm...common sense tells me that all the open lines, you will have 2 coming out of the firewall, you can cap. Probably some shorter bolts to go in the holes that held on the a/c compressor, I am not sure if on a 2.2 those bolts hold anythign else other than the a/c compressor or not, if they do, you will need some shorter bolts.
i am just asking i am removing it from my z24
John Wilken wrote:Be careful when opening up the lines. Just because the ac doesn't work doesn't mean there isn't still refridgerant in there, and it's not something you want sprayed in your face or on your hands.
yeah the reridgerant is all out
All for 2.4L LD9 motor...aka your Z24. Also when I removed everything its weight was only 33 lbs. Just to let you know.
Belt only no pulley. Advanced autoparts. 345K5 belt.......Might need longer belt size it is not the same from all suppliers. I'm unsure why. ~~shrugs~~
GM bypass pulley 2.4L p/n # 24574519.
Just because...GM bypass pulley 2.3L p/n # 22533199.
does anybody actually notice any gains from removing the ac?
I really think most of the gains were in my head.
-MD- LD9 wrote:I really think most of the gains were in my head.
That's the first sign of exhaustion from driving in the summer time with no a/c lol
'96 Cavalier Good ol' Pushrod 2.2
-24X,000 miles on factory build
-Some oil loss between changes, me thinks it be rings.
-MD- LD9 wrote:All for 2.4L LD9 motor...aka your Z24. Also when I removed everything its weight was only 33 lbs. Just to let you know.
THANK YOU i been looking for that part number for ever i am also getting a UD crank pully but also adding the gm s/c
LarryMartin830 wrote:-MD- LD9 wrote:All for 2.4L LD9 motor...aka your Z24. Also when I removed everything its weight was only 33 lbs. Just to let you know.
Why would you get an underdrive pulley if you want a supercharger. You would be geting less boost with a underdrive pulley.
I have a pretty red stock sized lightweight pulley with your name on it if you want...it just PM me.
Just ask for the "non-ac belt". After that, you DONT HAVE to remove all the other junk, but you might as well... you shouldnt have to cap anything bc nothing will be flowing through the lines.
www.bradsairsoft.com
CheesyPackerFan wrote:Just ask for the "non-ac belt". After that, you DONT HAVE to remove all the other junk, but you might as well... you shouldnt have to cap anything bc nothing will be flowing through the lines.
The 2.4 was not offered with a NON-AC BELT, they used a A/C bypass pulley with a stock belt size.
Also capping the lines the come out off the firewall is a good idea to keep corrosion out of the system, and have better defrost on your windows.
-MD- LD9 wrote:LarryMartin830 wrote:-MD- LD9 wrote:All for 2.4L LD9 motor...aka your Z24. Also when I removed everything its weight was only 33 lbs. Just to let you know.
for what i am looking for i can't use red
