Pistons - Performance Forum
Pistons
Sunday, September 17, 2006 6:59 PM
Couple of quick questions. Can pistons from a 96 2.2 work in a 2000 2.2?? I own a 2000 and blew 3 pistons, so I got another engine (before doin my research) that was a 96. I have dropped the 96 engine with my 2200 head on it, into my car. I had to change the crankshaft positoin sensor to the 2000, well now I am out of time BAD. Only solution I can think of is to fix my 2000 engine and drop it in. Is there any other solutions??
Thanks in advance
Re: Pistons
Sunday, September 17, 2006 9:00 PM
You may have to put your 2200 cam in, as your 200 ECU won't play well with the 2.2L cam timing notch. Other than that I can't think of anything.
fortune cookie say:
Re: Pistons
Monday, September 18, 2006 1:56 AM
The pistons will fit, but you would have a greatly reduced compression ratio. The older pistons have a deeper dish, designed for the older design combustion chamber.
The '98+ crank and camshaft have the timing notches ground at different angles than the older crank and cam, hence the timing problems. You must use the crank and cam from a '98+ motor to get the proper timing.
Either rebuild the 2200 you have or get another engine from a salvage yard, or buy a new engine.
Re: Pistons
Monday, September 18, 2006 7:35 AM
Thats what I thought I would have to do. So negative on using the 96 pistons in the 2000 engine? Since there would be lower compression. Oh well, I kick myself in the rear for not researching fully before hand. Thanks for the help guys.
