Engine Mounts? - Performance Forum
Engine Mounts?
Sunday, December 10, 2006 7:58 AM
I noticed on the turbo tech site that it says there is two tranny mounts for my car (unless im reading it wrong)...but it shows two dif types...ill post links...
http://www.turbotechracing.com/productcart/pc/viewPrd.asp?idcategory=550&idproduct=4915
thats showing front an rear...but it looks dif from...
http://www.turbotechracing.com/productcart/pc/viewPrd.asp?idcategory=654&idproduct=1274
and here is the other one.....am i missing somthing here...witch one is thr right one...or is one just bushings? im lost? lol seems like its simple but i can understand why its showing two types for the same application?
Re: Engine Mounts?
Sunday, December 10, 2006 10:04 AM
both are just the bushings, one is Rksport i beleieve and the other is Turbo Tech Racing brand.....personally i have the turbo tech racing ones and they are sweet. and so is TTR
Re: Engine Mounts?
Sunday, December 10, 2006 12:27 PM
Go with the solid TTR ones. You will be happy with them.
Re: Engine Mounts?
Sunday, December 10, 2006 12:46 PM
aights...what do u guys think about this....
RKSport Lower Engine Mount Cavalier/Sunfire 1995-05
Turbo Tech Racing Upper Engine Mount Chevrolet/Pontiac Cavalier/Sunfire 96-2002 2.4L and 1995 2.3L
Prothane Manual Transmission Mounts Cavalier/Sunfire 1995-05
Also....im going to be putting a turbo on...going to go with a nice turbo setup that can run a high amount of boost....not sure on the turbo setup yet...but im going to try an make alot of power.... so having said that...stage 2 or 3 clutch kit? keeping in mind this will be driving on the road everyday when weather is nice?
Re: Engine Mounts?
Sunday, December 10, 2006 6:16 PM
Make sure you get the solid trans bushings. and as for the upper, check to see if he has the solid one not the replacement.
Re: Engine Mounts?
Monday, December 11, 2006 12:08 PM
I got the Engine mounts top an bottom...also got the Tranny mounts....im woundering what to expect...for install?
Re: Engine Mounts?
Monday, December 11, 2006 12:14 PM
Upper mount takes 30-45 min
Lower mount takes 30-45 min
Trans bushings take 1-2 hours (front and rear)
I have done the upper in 5 minutes, but I have done it many times over....
-Aaron
www.TurboTechRacing.com
Re: Engine Mounts?
Monday, December 11, 2006 2:29 PM
also the upper is a little easier with out a/c
and alot on the upper depends if you can get the jack posistioned just right so the motor doesnt move
lower takes me about 5-10 minutes
Re: Engine Mounts?
Monday, December 11, 2006 3:32 PM
have u done the trans...is it a pain...r there special tools u need?
you scratch my ride IMA EAT YO CHILDREN
Re: Engine Mounts?
Monday, December 11, 2006 3:40 PM
probaly just some wrenches. a jack.
Re: Engine Mounts?
Monday, December 11, 2006 6:15 PM
^^thats what i figured
Re: Engine Mounts?
Wednesday, December 13, 2006 5:19 PM
Does anyone have a few pictures of them changing the mounts. If not ill take some pics when i change mine.
