crankshft weight - Performance Forum
crankshft weight
Wednesday, December 27, 2006 5:49 PM
Does anyone know the most you can take off of a stock 2.4 crankshaft. we have been trying it and the most we have got off is just short of ten pounds. was wondering if anyone has tried more then that
Re: crankshft weight
Thursday, December 28, 2006 9:59 AM
You do realize the counterweights are there for a reason, right?
I don't see how else you could possible have gotten 10 lbs from our crankshaft.
"Youth in Asia"...I don't see anything wrong with that.
Thursday, December 28, 2006 10:23 AM
we put that crankshaft in a 2.3 havnt had a problem with it yet the hard part was getting the ring on for the sensor. we have 3 others ones with about 8 pounds taking off and there still running. our cars our race only. we did have one blow up it did bent the crankshft had to throw it away. i will have to get a pic of one when we rebuilt one of the motors. but most of the v8 engines we do dont have really anything for counter wieghts so we just got rid of them along with the balence shafts with the oil pump change.
Thursday, December 28, 2006 10:59 AM
i would like to see a before and after pic of the crankshaft just to see what you took off
Thursday, December 28, 2006 11:17 AM
i might have the one that was the blowen up car i will get a pic of it. all we did was take of the counter wieghts. the engine runs rough at idle but after you get up to about 2500 it smoothes out very nice.
Thursday, December 28, 2006 11:24 AM
hmmm, could u shave off say like 1-5lbs without having any problems?
i would like to shave as much off my rotating assembly as i can-reliably though.
Thursday, December 28, 2006 11:34 AM
what kind of perfomance can you get out of doing this? just courious.
Thursday, December 28, 2006 12:28 PM
how do i get pic to show up im not that good with this kind of stuff
Thursday, December 28, 2006 2:45 PM
04ps wrote:what kind of perfomance can you get out of doing this? just courious.
1st step is a light flywheel, the result is similar. Spend money on a flywheel first.
I have a very light 2.3 forged Q4 crank (in a box).
Most 90 degree IL4's are naturally in balance. Justin what are you doing to verify the balance factor?
Light cranks are great, but it depends on the application.
Project S-Bird
Thursday, December 28, 2006 2:55 PM
http://www.msnusers.com/4cyl
nothing they are very well balenced i just notice a small vibration when at an idle but we havnt had any problems yet but like i said we only use our cars for racing no street driving. but total we have over 5000 miles of racing miles and no problems with the crank. the crank i have a pic of is the one where when we changed the oil pump to a 2.3 oil pump the plug for the old oil passage came out while racing. that is the reason why that crank got messed up. the one other picture is in our shop of my car.
Thursday, December 28, 2006 3:11 PM
not for me thanks... i'll keep my strong crank... even when an engine blows, if the crank is BENT, you know you did something you shouldnt have.
Thursday, December 28, 2006 3:25 PM
i have blowen up on with a stock crank to it bent also. it did make a really big differance on my car i would say it was at least the same as when i put the aluminum flywheel in.
Thursday, December 28, 2006 3:29 PM
justin kay wrote:how do i get pic to show up im not that good with this kind of stuff
you need a place to host the pic. like photobucket.com
then get the URL of the pic and then come here and click on the icon on the left of the smiley face. then go from there. but make sure you hit the preveiw button to make sure you did it right
Thursday, December 28, 2006 3:35 PM
the link i put up should work
Thursday, December 28, 2006 4:34 PM
they are there, we can see them, and i must say, it looks dangerously thin...
Thursday, December 28, 2006 7:55 PM
i didnt even notice. sorry
Thursday, December 28, 2006 8:28 PM
Well as looks go it seems you've taken the most you can out of it, at least the most I've ever seen and I'm sure thats the most anybody around the org has ever taken off so I'm not sure you're gonna get any advise about how to take more off from around here. You might try the quad4 forums you might have more luck there.
Thursday, December 28, 2006 8:55 PM
justin kay wrote:http://www.msnusers.com/4cyl
I can tell you right now that it isn't balanced. The rods, bearings, pistons, rings and wrist pin all have to be factored in to balance a crank. Even without those, I can tell that you are heavy on the rod journal side. But, as long as you are only doing this in race applications and not worried about reliability, then more power to ya, bro.
Thursday, December 28, 2006 9:18 PM
what kind of racing are you doing??
View my MySpace
Friday, December 29, 2006 6:31 AM
firebug wrote:what kind of racing are you doing??
this kind:
and damn i must say... that would be a ton of work to get that much off the crank, you guys do some amazing work, i cannot wait to have you do my 2.3 HO intake cam.
Friday, December 29, 2006 10:59 AM
we did take in the pistons and rods and rings and pins when we balanced it. the only down fall is some vibration while at an idle. i think it akes about 20 hours of machine work to get it that far.
Friday, December 29, 2006 1:02 PM
do you think u could just shave off a little, say like 5 lbs and stay within the "comfortable" side of things?
hell, even if you could shave off 1lb it would be worth it in my eyes.
Friday, December 29, 2006 1:14 PM
five pounds im sure you can do very comfortably.
i want to thank everybody on here and for the info i know that we would not be as far as we are now if it wasnt for everybody. when we started two years ago all that we knew was v8s from truck and tractor pulling. we learned more from this forum then any other site. we completly build our engines ourselfs so if there are any queston on other stuff that we might be able to do you can email me or post something. thanks
