Part Numbers for a rebuild - Performance Forum
Tuesday, January 02, 2007 10:11 AM
Whats up guys,
Im preparing to do a performance N/A rebuild on my ecotec and im in need of some verrification on part numbers.
From what I can tell:
Main bearings: 12591092
Rod bearings: 21018825
Gasket set: 12992309 (complete)
Now the gasket set seems a little overkill to me. Gm says that the complete set is the best way to go because if you buy the gaskets for a rebuild individually, it will be more expensive. The gasket set though is 352$ which is a little expensive.
Does anyone know part #s for basicly rebuilding a short block?? Do I have to buy a complete gasket set??
And how about the main and rod bearings? Are those accurate?
The main bearing in the gm build book is listed as: 21018819 Whats the difference??
"Go Before Show Yo."
CARCUSTOMS.NET, THE BEST SERVICE ON THE ORG!!!
Re: Part Numbers for a rebuild
Tuesday, January 02, 2007 11:50 AM
go to napa or arnold motor it will be cheaper from them than buying from GM
