tach signal wire - Performance Forum
tach signal wire
Wednesday, January 03, 2007 5:53 PM
Hello i have finished my guage cluster and i have 2 questions: I can tap the green/ white strip wire in the back of the cluster for the speedometer right?? the second one is: for the tach input i looked under the hood in the fuse box thats off to the side and theres a tach spot but it seems like there is nothing in it, i shoved the wire in it and it slid right through, the company told me to get the signal right at the negative on the coil, but the coils on the back of the motor and i will do anything no to run it there, any suggestions???? I dont think that i have to have a tach adapter as i have a stock one in my car.
thanks for the help as i am trying to mount the cluster tonight
thanks again
jason
gmto2nr
Re: tach signal wire
Wednesday, January 03, 2007 6:29 PM
as far as i know, if you have the 2.2/2200, you must use the tach adaptor. even though you would think the ecu would have a viable input source for a straight tach signal into the ecu (so it could fire the plugs acurately), there's no such wire to tap. the adaptor actually mounts between the hot wire going to the coil and the coil itself, converthing the individual power draws the coils use into a useable square wave tach signal.
Wednesday, January 03, 2007 6:41 PM
Ok so i have a autometer tach adapter can i use it even though its not a autometer tach???
Do you have a wiring schematic for this?
tach adapter
red wire
black wire
grey wire
red wire with a stripe
thanks for the help
ps how do you get at the coil with it in the back of the motor???
Wednesday, January 03, 2007 8:19 PM
yes you can use the adaptoron any tach you want. let me fireup my scanner and ill send you the exact intrucions if you dont have them
Wednesday, January 03, 2007 8:24 PM
i actually have them but not sure which schematic to use i know its for the coil application but is it for the gm coil or generic coil, please email them to me if you get this if its vehilce specific.
thanks
jason
gmto2n@yahoo.com
Wednesday, January 03, 2007 8:35 PM
email re-sent
Edited 2 time(s). Last edited Wednesday, January 03, 2007 8:40 PM
Wednesday, January 03, 2007 8:39 PM
or you can get a tach that reads 2 cyl and connected that because the tach signals from the car only read half of your rpms but if you set it to 2cyl it will read it correctly.
