i was wanting to get some ideas for the best injectors to to use for a 99 z24. its got an 086 head bored out and we run e85. if i remember right with e85 you should use 25-35% more fuel. was wondering what the best name brand and size of injectors you think i should use. thanks
is it nessacery to replace the injector if so whats a good size
you put e85 in your cav?
i guess thats possilbe if you replaced your gas tank and feul lines
i didnt change anything to put the e85 in. but i do know now that i need bigger injectors and a good place to get them from.
do you mean like flex fuel if so no i run 89 on the street and 106 octane at the track
justin kay wrote:i didnt change anything to put the e85 in. but i do know now that i need bigger injectors and a good place to get them from.
You need a lot more than that. When the Ethanol starts corroding the entire fuel system you'll find out why. Hopefully you tested the tank and all the lines with alcohol before you did this.
Additionally, your ECU is going to try to target a A/F ratio of ~14.7:1. When running E85 you need to have something like 9.6:1 to be stoich. So you'll probably run the engine lean and pop it by runing E85.
scottymac wrote:do you mean like flex fuel if so no i run 89 on the street and 106 octane at the track
Quit jacking every thread you see. Your becoming a nusence. This has nothing to do with your car AT ALL so stay out. Make your own damn posts or try searching for the information.
5K PB: 24:50
10K PB: 54:26
