Walbro Fuel pump - Performance Forum
Walbro Fuel pump
Sunday, January 14, 2007 1:27 PM
Which walbro fuel pump will work for my 2.2L any modifications needed when purchasing one? Also were can i buy one, thanks for all help
Re: Walbro Fuel pump
Sunday, January 14, 2007 1:58 PM
where to get one
searching does wonders
Sunday, January 14, 2007 7:15 PM
ok i found them now which make do i go to bc chevy isn't in there category
Sunday, January 14, 2007 9:15 PM
Click
Pump: F20000169
Installation Kit: #27
Flex Hose
For a 2200/2.2L OHV though, I would consider doing the Blazer pump install.
"Youth in Asia"...I don't see anything wrong with that.
Tuesday, January 16, 2007 9:42 AM
DO NOT get the 255 LPH one.. it sucks, I keep having issues around 1/4 tank.. I have heard more luck with the 190 lph. I believe there is a mod here too that is supposed to fix the issue... but then you have just ruined the nice cnister in the tank, so get the 190 and you will be happier, unless anything has changed since I did my pump.
