2200's leans out while rpms go down - Performance Forum
Monday, February 05, 2007 10:36 PM
I heard a rumor that the 2200 leans out while the rpms are dropping. Can anybody actually confirm this or is it not true?
I want to share something with you - the three sentences that will get you through life. Number one, 'cover for me', Number two, 'oh, good idea, boss', Number three, 'it was like that when I got here.'
Re: 2200's leans out while rpms go down
Tuesday, February 06, 2007 2:25 AM
as far as i know, all engines that are fuel injected lean out while revs drop.
Tuesday, February 06, 2007 3:07 AM
Isn't it called decelleration de-enrichment or something like that? I think if you check out the tuning fourm, there is a fule and/or spark map for decelleration.
Tuesday, February 06, 2007 9:16 AM
it is normal, and probably won't hurt anything if thats what your worried about. my old boosted 2200 would run rich under boost, then let off and run 17:1 afr while the rpms drop...car ran strong for a long time until the starter went out
Tuesday, February 06, 2007 9:31 AM
not all of the GM's had DCOE enabled from the factory, it was sort of a mix and match thing, certain cars got it and others didn't. I believe most of the manuals got it though. Its also a very good fuel saving feature.
_______________________
** Flat Broke Racing Inc.**
Tuesday, February 06, 2007 9:43 AM
Its called DFCO and all J's at least from 97 up had it. Deceleration Fuel Cut Off.
Tuesday, February 06, 2007 1:27 PM
Shifted wrote:Its called DFCO and all J's at least from 97 up had it. Deceleration Fuel Cut Off.
Ah yes, that's what I was shooting for; I couldn't remember the terminology
Tuesday, February 06, 2007 1:43 PM
except i was running MS , which also has it though
