hey fellas im looking to see if there is a bigger oil pan for the 2200 other than the moroso pan that howell sells because i dont feel like spending $500 on an oil pan... im running a turbo so i would like to have more oil to run it more efficiently
thanks
well im going to use the il pump out of a 93 cavalier but im using the high volume pump so i was looking to get possibly another quart if i could... i also plan on putting a cooler on it so i think with the cooler and the bigger filter that it should be ok
well what would be sufficient power to use the high volume? i am going to be turbo charging it so im hoping to run around 10-15psi but i dont know yet.... the internals are all redone and basically i just want a pump that wont fail me especially cause my head took so long to get done from the machine shop.
thanks a whole lot..., you have been very helpful, i will just get the stock one
I bought a HV pump a few years back, still have it, probably won't end up using it though. By the time you need it, your car would probably benefit from a dry-sump system more...
fortune cookie say:
