Quick HO Manifold Question - Performance Forum
Thursday, February 15, 2007 4:31 PM
Im currently working on polishing my HO manifold
I was wondering what something did on it and do i need it for my Twin Cam?
I shaved off all the tabs and casting lines and just wanna know about this thing with the arrow and circle My manifold just came as a empty hole
Thanks
Re: Quick HO Manifold Question
Thursday, February 15, 2007 4:34 PM
yes its unused unless you want to run your pcv hose to it.
Paul
Thursday, February 15, 2007 4:45 PM
That would be too much vacuum, with out an oil to air separator....... and I still think it would to much.
Chris
'02 Z-24 Supercharged
Thursday, February 15, 2007 4:57 PM
just block it off
Thursday, February 15, 2007 6:39 PM
One more question
I have the Vibrant Performace intake but when i cut it to tit my HO mani ill have to move the hose that runs to it which i believe is the PCV hose
Anyone have a solution for this?
I can take a pic of the hose im talking about if needed Thanks
Thursday, February 15, 2007 6:42 PM
put a breather filter on the end
Thursday, February 15, 2007 8:05 PM
You know you have to block off your EGR too right?
Thursday, February 15, 2007 8:49 PM
My cavy is a 2000 i dont have a EGR
Put a breather on the end of the PCV tube?
Thursday, February 15, 2007 9:28 PM
sUiCiDe wrote:My cavy is a 2000 i dont have a EGR
yes
For your first question, I have a seperate fitting in that hole which I have plumbed to my MAP sensor. Or you could just plug it like the others suggested.
"Youth in Asia"...I don't see anything wrong with that.
Thursday, February 15, 2007 9:34 PM
Ahhh 2000, sorry for my confusion.
Thursday, February 15, 2007 10:23 PM
yeah
Friday, February 16, 2007 12:28 PM
Another question
Do you know if you can buy one of those hole filler things thats at the far right of my picture?
Looks like its screwed in with a Hex or Allen key id like to get one to fill the hole where i took the sensor out on top of the manifold cause i dont need it
Saturday, February 17, 2007 11:02 AM
That large pipe on the rear, I ran Brake booster hoses to that (on mine it has the smaller fitting, so I used it for my MAP sensor). Or you can pick up a cover for it.
Large hole in the top (MAT Sensor hole) You can either use the 2.3 MAT (think IAT) sensor, and not use the one in the intake tube, or go to a hardware store and get the correct size pipe plug for it.
NEVER run your Air/Oil seperator hose to the intake manifold!!!
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Saturday, February 17, 2007 4:21 PM
Do i have an air/pil seperator? on my 2000 Z?
Do you have a detailed pic of your install? Like to get a good idea of all lines ran
Or Does anyone have a good pic of your installs
Saturday, February 17, 2007 4:30 PM
Taetsch Z24 wrote:That would be too much vacuum, with out an oil to air separator....... and I still think it would to much.
Chris
Bingo. Found that out myself !. (Unless you enjoy a car that idle's @ 4000rpm....
BLOCk IT !
My Cav
I give up...
Sunday, February 18, 2007 5:06 PM
Darren, I sent you this pic I thought. It shows most of the connections and where they end up.
Sunday, February 18, 2007 10:36 PM
just so i dont start a new thread:
i understand it goes
yellow -> fuel rail
red-> map sensor
but for the white, i know the f-body iat sensor should go in this hole or am i mistaken?
and
the circled nipple here can be blocked off or a breather filter goes on here
also...
in this same pic you can see the allen key pipe plug, can this be used at all?
Sunday, February 18, 2007 10:59 PM
Clears up alot of things for me
What do most of you do with the hose that runs into your intakes?
I know my intake came with a longer piece of tube to extend far enough but ill be cutting it now where it plugs in
Thanks
Monday, February 19, 2007 10:16 AM
LAFNGAS wrote:j
Breather filter = vacuum leak
Monday, February 19, 2007 10:46 AM
can you use the stock t/b bracket with the ho mani.? Does anything have to be done to it and as well as the cables?
Monday, February 19, 2007 1:34 PM
I used the stock bracket. I used a 2.4 tb and bracket and all i did was run the cables under the lip of the battery tray.
Monday, February 19, 2007 8:30 PM
sUiCiDe wrote:Clears up alot of things for me
Thanks
Tuesday, February 20, 2007 7:23 AM
LAFNGAS wrote:just so i dont start a new thread:
yellow -> fuel rail
red-> map sensor
quote]
Tuesday, February 20, 2007 12:19 PM
No i mean an after market WAI
You run a large rubber hose to it i think its the crankcase vent line
Do you guys just drill a new hole in your intakes and attach something?
Tuesday, February 20, 2007 12:42 PM
sUiCiDe wrote:No i mean an after market WAI
Yup
But I had a problem with unecessary amounts of oil collecting in the TB and manifold... so I said F*** that and bought a K&N crankcase filter.
