weird exhaust sound - Performance Forum
weird exhaust sound
Friday, February 23, 2007 4:35 PM
Hey guys, just got my header all tightened up and I am pretty sure it is no longer leaking. However, I have one problem still left, it sounds like the header itself is gargling anybody know what this could be? I am starting to think it might me the cat but i am not sure, also the exhaust is loud as hell now is this normal? BTW its the RKSPORT 4-2-1 and i used a new gasket any help would be appreciated, thanks ahead of time
Re: weird exhaust sound
Friday, February 23, 2007 4:57 PM
anybody?
Friday, February 23, 2007 5:23 PM
Ive got the pacesetter 4-1 header and I used the gasket that came with it and I have a header leak like crazy. Your better off getting an after market gasket and make sure you torque those bolts correctly starting at the center and working your way out.
Watch out there nah!
Friday, February 23, 2007 5:37 PM
well the only thing is i got a new gasket from the gm dealership the one that costs eleven bucks, my old one was in two pieces, so did you mean the two gaskets from the midsection(where it goes four to two)?
Friday, February 23, 2007 5:50 PM
nice you tighten up the bolts in sequence ? and balls ? i pretty sure thats it.. or it might be were it meants the exhuast get under there and check
Friday, February 23, 2007 6:03 PM
Bolts were tightened up in sequence, from center out, but what do you mean by balls? i feel kinda like i should know what that is, but other than that I did check where it met up at the exhaust its about as tight as I wanna make it because I know those f***ers are probably gonna snap if I tighten them anymore.
Saturday, February 24, 2007 8:51 AM
just bumpin this up there
Saturday, February 24, 2007 10:43 AM
With a header your exhaust will get louder. Being that you have the RKS header, the tone will change and it will kinda sound like if you have some wild cams as you accelerate. Blame that tone on the 4 primary tubes, 2 short ones and 2 long ones. Because of that, that may be the reason you here it "gargling"---- it is the design.
As long as you got the new gasket and re-tighten the bolts after roughly 250-500 miles, you should be fine.
>>>For Sale? Clicky!<<<
Saturday, February 24, 2007 11:39 AM
thank you i appreciate it so much, i have been trying to figure this out and getting no help. However i think something is still messed up it kinda sounds like its still leaking. what works best for testing for exhaust leaks blowing cigarette smoke? stethoscope? soapy water while it's cold? what?
Sunday, February 25, 2007 7:50 AM
take it to a exhaust shop
Sunday, February 25, 2007 9:22 AM
i recently got a obx 4-1 header installed. it changed the sound like you can hear the cylinders fireing or something. i think it is because the pipes are separated for longer. i think a larger resonator would help.
Sunday, February 25, 2007 11:30 AM
will o wrote:thank you i appreciate it so much, i have been trying to figure this out and getting no help. However i think something is still messed up it kinda sounds like its still leaking. what works best for testing for exhaust leaks blowing cigarette smoke? stethoscope? soapy water while it's cold? what?
Soot. Look at all the spots where it is bolted, if you see black soot marks, then that's where it's leaking.
When it is not leaking, it should be clean in all of its connections.
Best of luck.
Sunday, February 25, 2007 5:17 PM
yeah i saw that in one of the posts i found and remarkably no soot what so ever. I went through one more time and tightened what was "loose" and now its beautiful, and sounds great.
yeah neb, i got the same thing but i hope a resonator does help that, im gonna get that and a high flow cat, then see what its like
Anyway, thanks for all the help guys, and btw don't you just love having more mid range power
Sunday, February 25, 2007 5:30 PM
let me know if the cat makes a diferance. i love how much i can spin my tires
Sunday, February 25, 2007 6:24 PM
will do, and i wish i had a manual so i could chirp into second and third, but the b&m makes me happy too
