3 bolts on my 995 head are stripped and cant be tightened what can i do to fix it?
http://www.gadomestics.com/
Tap and Die, then new bolts
die? new bolts?
yeah a tap allows you to rethread bolt holes and such, a die allows you to rethread stripped bolts, and i would suggest new bolts because they probably wont fit right or they might strip again.
Don't do that.
Witch bolts are sripped?
The good way to do it is with helicoil. That way you don't have a ghetto repair.
Gilles
2.3 Ho
what size heli coil tap do i need for 570-8? the heli coil pack that i bought doesnt have the tap what drill bit size do i need?
yeah mfk is right that would work alot better
thanks for the help.
