rev limiter question... - Performance Forum
Friday, February 23, 2007 11:14 AM
What rpm does your rev limiter kick in? i dont want to remove it or any or that other crap, i just bought a new gauge cluster (one w/o a tach to one w/ a tach) and i just want to make sure that tach. is accurate.
Re: rev limiter question...
Friday, February 23, 2007 11:26 AM
Friday, February 23, 2007 1:46 PM
anyway to bypass rev limitor
Friday, February 23, 2007 2:13 PM
HPTuners
Friday, February 23, 2007 2:15 PM
why would you want to bypass it? do you want to blow your motor? i am still new to j-body (only been a member for a couple of months) but i know not to ask that retarded question... or even why.
Friday, February 23, 2007 2:17 PM
Shifted wrote:HPTuners
or you could do that, but i just dont know why you would want to. i can understand about the speed limiter but not the rev limiter,...
Friday, February 23, 2007 2:38 PM
There are some out there that need to make the rev limiter higher. Like Skwirl, I beleve he is hitting 7200 rpm, and soon is talking about 8000+rpm. It all depends on what you are doing with the car. HP Tuners is the best way to do any kind of tuning for our cars, well I guess the only way.
In the planning stage for an all American TRD Cavalier.
Friday, February 23, 2007 2:53 PM
moving the limiter is used usually when the powerband is raised...such as a built head or just cams can do this and put your peak power out of the stock powerband....another reason could also be to get your car as close to peak power as possible after every shift..
Friday, February 23, 2007 10:54 PM
Do most Dyno/Tuning shops have HPTuners? Is there a way to adjust your speed limiter witjout getting rid of it or is that HPTuners as well? Where can you purchase HPTuners?
Saturday, February 24, 2007 1:31 AM
Z24HO wrote:There are some out there that need to make the rev limiter higher. Like Skwirl, I beleve he is hitting 7200 rpm, and soon is talking about 8000+rpm. It all depends on what you are doing with the car. HP Tuners is the best way to do any kind of tuning for our cars, well I guess the only way.
Let's say the easiest/ most practical for the majority of J-body owners. It is FAR from the best and DEFINITELY NOT the only.
01 zed wrote:moving the limiter is used usually when the powerband is raised...such as a built head or just cams can do this and put your peak power out of the stock powerband....another reason could also be to get your car as close to peak power as possible after every shift..
You set it where you will have the most area under the power curve (which is why gearing is so important). Perhaps that is what you meant though.
Scott Kostura wrote:Do most Dyno/Tuning shops have HPTuners? Is there a way to adjust your speed limiter witjout getting rid of it or is that HPTuners as well? Where can you purchase HPTuners?
HPTuners
"Youth in Asia"...I don't see anything wrong with that.
Saturday, February 24, 2007 9:47 AM
Kendal, just for your info the 2200/2.2L OHV rev limiter is at 6000.
Sunday, February 25, 2007 8:33 AM
Kendal Brown wrote:why would you want to bypass it? do you want to blow your motor? i am still new to j-body (only been a member for a couple of months) but i know not to ask that retarded question... or even why.
well i dont think its that "retarded of a question" for one. i dont know what your doing putzzing aroung in GA but im dirt track racing in iowa buddy.for two its a half mile dirt oval "high bank" im hitting the rev limitor in third gear just entering the corner i dont think ill blow my motor getting a couple more r's out of the motor. every buddy else like always thanks for the help schmitzracing
Sunday, February 25, 2007 8:54 AM
ladies and gentleman.....one of the first non stupid noobs. Kendal you are OK in my book. keep that mindset and you'll do jsut fine here
