just like the title says.  what is everyone running.  I've searched but found a lot of different crap spread out beyond more crap, so it didn't really seem to clear what the best route would be.  What is everyone using, and what kind of problems did you run into, and how exactly did you go about doing it?
i think you need to go back and read your post again...which sensor? cps?iac?tps?iat? theres alot of sensors on the 2.3 and the 2.4 ..which are you refering to?
I guess I should get more sleep.  What sensors is everyone running in the 2.3 throttle body.  the 2.4 sensors, or the 2.3 sensors.  What problems have people run into, and what made things easier.
All 2.3L sensors...And make sure they are working correctly.  My TB was water logged and F*** up the TPS.  I bought a brand new 2.3L TPS and all is well.
"Youth in Asia"...I don't see anything wrong with that.
you always use the sensors that are for that t/b 2.3 t/b = 2.3 sensors.....2.4t/b = 2.4 sensors and youll be golden and as brian said make sure the sensors are good
