Ecotec exhaust setup, what do you think? - Performance Forum
Friday, February 23, 2007 3:47 PM
I'm going to be doing a full exhaust on my 04 LS, and have compiled a list of parts I am going to be using, but want to run it by ya'll first, let me know if i'm missing anything, or should rethink any particular item, and why. Currently, I have an aem cai on the car, and that is all.
Pacesetter header: black painted
(yes I plan on sand blasting and repainting this with high temp paint)
Magnaflow 2.25" high flow cat
Tenzo TT2225T Type-2 Stainless Muffler with 4" Titanium Tip
I decided to initially go resonatorless, to see how it sounds, but if anyone has$.02 they wanna throw in on that, do.
I have a new gm manifold gasket on the way.
2.25" mandrel bent piping
Has anyone had any problems with the magnaflow 2.25" cat throwing codes?
Other then that, I can't think of anything I'll need.
Re: Ecotec exhaust setup, what do you think?
Friday, February 23, 2007 4:16 PM
with the Magnaflow cat, make sure you use the 94035 cat, and not the 91035.
with the header, I'd say save the money and get the ceramic coated version. you'll be happier in the long run.
Desert Tuners
Friday, February 23, 2007 5:04 PM
yes, the 94035 is the one i have planned, and everyone keeps saying spring for the ceramic coated one, but what is the major difference? why would i be happier is the better question.
Friday, February 23, 2007 5:57 PM
yes youll be happier with the coated
paint isnt a thermal barrier , the coated header uses a ceramic coating , and it is a thermal barrier , and keeps more heat inside the header
as well as keep under hood temp down
Friday, February 23, 2007 5:58 PM
Even if money is an issue you could use the Tsudo 4-2-1 stainless from ebay. Should be the same price as the unpainted pacesetter and 2 of the fastest ecos on the boards are using it. Also you will want a resonator...i would reccomend something like a 22" or so and you wont regret it. good luck
Friday, February 23, 2007 6:06 PM
I was thinking about the tsudo... maybe that's what I'll try.
Who has a stainless resonator? Haven't seen any on gravanatuning or turbotechracing...
any good place to get one?
Friday, February 23, 2007 6:15 PM
for the resonator you could go anywhere, i got mine from summit or you could check out jegs
Tuesday, March 06, 2007 4:49 PM
decided with a tenzo header, any suggestion on any particular seller? A recommendation as it were. seems good buisnesspeople deserve more business I think.
Tuesday, March 06, 2007 7:13 PM
I didnt know tenzo made a header...do you have a link?
Tuesday, March 06, 2007 7:29 PM
Entirely my bad, I meant tsudo. I even priced them and checked out some of the sellers on ebay, just typed it incorrectly... my bad.
Tuesday, March 06, 2007 11:13 PM
looks good for a complete setup. painted header is fine, tsudo is fine, ceramic is better. i have the pacesetter painted, magnaflow cat, 2.5" mandrel piping and a N1 style muffler (basically the same as the tenzo)
its so loud. i'll be putting a resonator on in a couple weeks.
if you want it loud and a little raspy go without the resonator. a little deeper and quieter go with a resonator
