Called dealership and price is $70+tax on the 2.4 ac bypass pulley,anyone know where to get it cheaper???I need this ASAP,thanks
did the smaller belt not work...    or???
i would say $70 sounds about right, you could try gmpartsdirect.com, they might be cheaper, but they will rape you on the shipping so who knows if in the long run it will be any cheaper...
SHoof :checked ebay and they only have it for the 2.2
zyaaaa:I tried numerous belts and the closest was a 350k5 using the tensioner pulley but for that to even work the tens. pulley  ends up being on the rib side of the belt or run the belt on the other side of the tens. pulley and it's not very tight,confused yet?So I eliminated the tens. pulley and ran a 345k5 which I had to loosen the alt. to get on and that belt started squealing and smoking.So in conclusion I am putting the tens. pulley back on and running the 350 again which only squealed from time to time and I will probably by the bypass and run the stock belt
O1CAV:I will do that right now thanks
gmpartsdirect is the cheapest at 51.62 total w/shipping,thanks
I've heard parts not shipping from GMPD for 2 weeks. So if you need it ASAP you may just want to get it from the dealer, unless they take 2 weeks too.
