Im looking for some input on the secret cams. what do you guys think. what kind of power does it add and is it worth it.
www.rdracing.110mb.com
i sure hope so, i've bought the set, it's on the way as we speak.
When I step on the gas, I want people to think the world is coming to an end! - Homer J. Simpson
Definitely worth it
"Youth in Asia"...I don't see anything wrong with that.
the cams cost nothing, its installing that hurts. shops here in Canada want around 400 to 580 to do the install
. NOT including gaskets... and other parts. I noticed a great high end gain past 3500 rpm. MIxed with a full exaust, + the Lo mani and 56mm tb it was a HUGE difference.
My Cav
I give up...
I like mine
2012 numbers - 4SPD
AUTOMATIC!!
love them!!! get yourself a haynes or chiltons, the gaskets, and anything else you think you need i used the cam lube stuff, and the cams of course and do it
I didnt feel much.. same number at the track.... the only thing i felt was a weaker take off and a bit better top end (meaning 30 - 70) what the cams deduct from low rpm's it makes up in top end... but it comes out to be equal i think.. and our 2.4l's arnt known for good top end either , mine outshined alot of other 4 bangers off the line but that changed a bit now .
installing them is pretty simple if you have a jack, 2 jack stands, 10,13,15,18, 30mm sockets, pulley puller, 2ea. 3/8" aligning dowls, and about 4-5 hours. As far as gaskets go, you can reuse them, just make sure the engine is completely cold before you start the swap, and torque everything to spec with a torque wrench... and use loc-tite on the cam gear bolts.. pretty simple if you are willing to try it.
heres a better question, has anyone compared these to a set of aftermarket cams???
^^ no, no one has ever done a dyno before/after, or compairing these cams to others with identical setups... couple of peeople have tried setuping up a "donataion" based dyno run, but no one wants to helps... so doubtful it will ever happen.
The cams are almost identical to the JBP cams which dynoed 22 WHP or something.
My car has the cam swap, I am not a big fan, did not see a difference but that could be for a lot of reasons. I am having boost issues with my car so that could be it. As far as reliability they seem to be fine and a stock like idle.
Good luck with the install, it is time consuming just a lot of bolts, other than that it is okay install.
2.3-2.4 HO ADAPTER FLANGES 65$ shipped, Check GP Forum!
well i think this is somthing i will be looking into after i get my ho mani on the car
those damn 10mm timing cover bolts are a bitch to do.
ge_forcez22 wrote:those damn 10mm timing cover bolts are a bitch to do.
Indeed, but those three 17mm ones that connect that whole top motor mount assembly to the block are a pain to try and clear the body (with the motor still connected to the trans).
18mm... and yes they suck, lol, Gear wrenchs FTW
engine outside of the car ftw.
supercharger installation, too.
supercharged 2.4L alero
www.cardomain.com/ride/2168613
cams are well worth it...and while you have all that apart do ahead and put a new water pump on and a header if you havent already....makes life easier with everything all apart all ready.....and you could do it yourself not too hard just make sure to get a torque wrench and tighten everything down properly
thanks for the help ill make sure that i tell you'll how this went sometime during the summer when i do the rebuild
Put 'em in, took 'em out 3 months later in favour of stock. Running a custom grind now which i'm 90000x happier with.
That's my story.
-Chris-
-Sweetness-
-Turbocharged-
With my ported head and oversize valves, they ran f'n awesome considering what they cost me (nothing). And I did the work myself... so no labor either. I was doing the head anyway... so the gaskets didn't cost me extra. I did the water pump at the same time too... $30 or so for that...
I was happy with them... no codes... guaranteed reliability.
I feel that to make the cams work right tuning is required. I do not have beofre and after dyno's for just the cams, but I only gained 6whp on cams, header and full exhaust and tranny mounts. Note car was running pig rich and tuning would gain some power.
Edited 1 time(s). Last edited Friday, February 09, 2007 8:31 PM
Hey guys just looking for some wisdom and some good opinions. I plan on doing this cam swap as well. I am also going with 40 over 10.5 -1 pistons, eagle rods. I plan on sending my balance shafts to jbp to get Neutral Balance Shafts. Do you think I should go with stronger springs for the cams? Or is stock ok? I also am looking into having the crank lightened but I was advised not to because it can cause balance issues. Any ways what do you think of this?
Stronger springs for what? A garunteed premature valve wear? You dont need stronger springs for these....not enough lift to warrant the downfalls of stiffer springs. Stock springs work just fine.
