Performance part question - Performance Forum
Thursday, May 10, 2007 2:47 AM
I've a 96 Z24 and would like to put in some mod. When I shop for parts, can I go for different model year? For example can I buy a header for 98 LD9? I see some parts from www.mantapart.com/ for 96-99 LD9. Where else I can look for parts? One last thing, did the jtuner turbo kit work on 96 LD9?
Thanx
Re: Performance part question
Thursday, May 10, 2007 12:48 PM
yes you can use parts from 96 to 99. you are limited to 99 because of engine changes namely they took the EGR off changing compression from 9.5:1 to 9.7:1 and they swapped from low impedance fuel injectors to high. I've only heard bad things about Mantapart and yes J-Tuner makes a turbo kit but if you go to their website you'll find they cut back and 5 people (at least was last time I checked) must order them before they will ship them out.
Thursday, May 10, 2007 1:04 PM
Is there any other web site I can order performance parts?
Thursday, May 10, 2007 3:54 PM
Jbodyperformance.com; Summitracing.com;Carcustoms.net;Cardomain and many more all depends on what you are looking for.
Thursday, May 10, 2007 5:32 PM
also apluserformance.com, and turbotechracing.com.
stay away from maximumboost.net
Thursday, May 10, 2007 5:52 PM
Yeah I heard alot about maxiumumboost.net.....more than enough
Now I've another question, what kind of mod/how possible to make 160-180 whp on a budget, say $800? I'm a mechanic and been modding my GP for years. So I'll do all the work. I'll be N/A for now and maybe turbo later. I heard alot about "Secret Cam" swap with 086 head. But that seems alot of work to do a 086 head swap. Also the exhaust manifold/header seems not much choice. And I've a 96 which is not supported by HPT. Any suggestion?
One more thing, I'm thinking about doing a complete 00-03 2.4L engine/tranny swap due to it has 96 harness, and it was crank but no start now...... . How hard to do this swap? I know the motor itself is good. It might be fuel or spark problem. Can I keep the motor and use 086 head, 00+ harness and 00+ tranny?
Thanx alot
