TPS sensor? - Performance Forum
TPS sensor?
Friday, May 25, 2007 10:03 AM
I have a 2000 2200 3 speed auto and i went wot the other day and while im doin it my check engine light turns on. I pulled the codes and they are running lean, and low voltage does anyone know what this might be? thanks
Re: TPS sensor?
Friday, May 25, 2007 12:15 PM
TPS sensors usually fail around the 20-25% on our cars, giving you awful lean situations around there (highway Throttle position),
what were the code numbers?? P03##??
